Question about Toshiba TDP-T90 Multimedia Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
Toshiba tdp-t90 projector. I rplaced the lamp on my projector but tossed the instructions on how to reset the lamp timer option. It has something to do with pushing several buttons at once
Set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Posted on Jul 22, 2010
What cable do I need to connect my PS3 to Toshiba TDP-T90?
You'll need a converter similar to the following, http://bit.ly/1hAPiMY
Oct 12, 2015 | Toshiba TDP-T90 Multimedia Projector
How do I reset the lamp timer to '0' hours when I replace the bulb?
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go.
Mar 18, 2014 | Toshiba TDP-T90 Multimedia Projector
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
Turns more green
apart from the lamp (which ive had several times) we did have a DLP chip cause this.
Nov 15, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
My Toshiba TDP-ET20U Multimedia DVD Projector will not play a DVD. I can hear it reading and reading it, but it will not play. The same DVD will play immediately on another DVD player.
Hi jennydority
Have you tried cleaning the DVD player's lens with a CD/DVD cleaning disc yet ?
Give it a go , it normally solves the problem.
May 06, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 projector, lamp
is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
Feb 16, 2008 | Toshiba TDP-T90 Multimedia Projector
COLOUR MISMATCHING
befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 Multimedia Projector Logo
968 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
