Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have a husqvarna 55. I put in a new carb, coil,
I have a husqvarna 55. I put in a new carb, coil, gas line, spark plug and gas filter. It starts but will not run off of idle. Tried h-speed idle screw w/no success. Looking for help please. What is the H/L start for the adjustment needles?
    Sniper:
  • 197 Answers
If you are still having problems I would check or replace white grommet inserted into cylinder and connected to manifold,they have issues with breaking or blowing out.This model also has problems with the black intake boot not sealing around cylinder and manifold,an easy check by spraying a LITTLE carb cleaner around problem area.
Posted on Nov 18, 2009
    Brigadier General:
  • 4,088 Answers
Preset both needles about 1-1/2 to 2 turns CCW from CW stop. Set H needle first after warm-up. At high speed, engine should 4-stroke with no load, but smooth out with light load(cutting wood). Set idle speed so that it will keep running, then adjust L needle so that engine tries to follow the throttle, but idles fairly smoothly. Readjust idle speed so that the clutch is not trying to drive the chain.
Posted on Aug 02, 2009
1984 Chrysler new Yorker 2.6l wont start. Replaced the fuel filter, new spark plugs and wires, new fuel shut off switch, new relay delay fuse, and a new ignition coil, oh yeah and a new starter. Ever hear...
Here's a quote from amy Chilton's manual for 1980-1987.
"Several types of fuel filters are used. One is located in the fuel tank of all the vehicles and is part of the fuel guage assembly. Second is a sealed paper element, in-line unit; mechanical system- located on the engine (above the fuel pump) or electrical system- located in front of the fuel tank. Third is a paper element, in-line fuel filter/vapor separator, housed in a fuel resevoir. Normally, the in-tank filter does not require changing. If it does, the fuel tank must be removed. "
This thing you describe sounds like the typical Chrysler in-line filter of its day. It is nothing more than the same generic in-line plastic see-thru filter you buy for your lawn mower except in the 70's and 80's it was covered in metal and had a Chrysler part number. A lot of guys added an extra filter in those days, it wasn't the best system. I would remove the outlet line and turn the fuel pump on, see if you get fuel. Replace if needed.
Nov 02, 2013 | 1984 Chrysler New Yorker
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Had broken gas line, fixed it and now want crank, put new plug in
Check fuel flow to the engine. Make sure fuel line to the carb has fuel filter on the in-tank end and that it is clear. Make sure there is spark at the plug. Make sure your air filter is clean. Make sure the bolts to the engine cylinder and the lower crankcase cover are good and tight. If all the above check out OK, then you may need to remove the carb and clean it. Possible small fuel line particles entered the carb after it broke so the carb may need to be partially disassembled and cleaned. Post back as needed.
Oct 02, 2010 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 55 Chainsaw (1999) - Runs OK for 1 minute then stalls
I think your on the right track
Blowing compressed air through your tank vent
is great but it is way more air than the natural asperation
that the saw pulls on it own
I would replace the vent cap and also look for a pinched fuel line between the fuel tank and the carb
Apr 07, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
643 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
