Question about Kenmore Washing Machines
Washer will not hold water start washing cycle and water runs out the bottom
    Brigadier General:
  • 4,088 Answers
Likely a damaged hose either from tub to pump or pump to drain hose. Could also be a cracked/broken pump housing or shaft seal. A further possibility would be a rust-through in the outer tub (which can be fixed with epoxy).
Posted on Aug 02, 2009
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
