Gaggia Brera works fine until it goes through brew cycle but the service door pops open. Shut the service door after it pops open and the machine works and makes coffee fine. I Recently descaled 2 weeks ago. The brew group has been cleaned.
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: Cuisinart DGB900BCC coffee machine. Problem is
I've solved my problem. Called Cuisinart customer service and spoke with a rep. The filter basket must be aligned. Shouldn't push down when putting basket into position. Also, cleaning underneath the bean grinder with pipe cleaner helped.
SOURCE: I have a 1st generation Gaggia Synchrony digital
Hi
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run's normally, your grind is to fine. Push the grinder lever to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this
Testimonial: "It was the grind! I had already cleaned the brew head. Many thanks!"
SOURCE: We've had our Saeco Incanto for about 2 years,
HI
I would suspect that the grinder has seperated. If you take out all the beans and look at the cork screw in the center, it won't be. It will be off to one side just a little. That is why you are not getting a good grind. the beans are going to the larger side and being chopped into large grinds. You might be able to take the grinder apart and snap it back together. Or it might be broken and it will have to be replaced. Email me if you need one.
