Question about Refrigerators
Freezing in refrigerator compartment - Refrigerators
    Novelist:
  • 116 Answers
Check thermostat ,adjust, thermostst may be to low, or faulty thermostat, replace,
Posted on Aug 02, 2009
3 Suggested Answers
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
Bat1956
  • 585 Answers
SOURCE: refrigerator compartment freezing
Experience tells me the design should maintain 40 -34 degrees in the refrigerator section when the freezer is between 0 and -10 You might check this if you have a thermometer for the job, and adjust the thermostat accordingly. Your unit may also have an airflow control (I didn't research) to adjust the refrigerator independent of the freezer.
Posted on May 25, 2009
Model KBF A25ERSS01 - S/N ECT2510800
I am not familiar with this refrigerator, but what you describe can happen if the refrigerator uses a motorized damper to control the refrigerator temp by varying amount of air from the freezer that circulates in the refrigerator compartment. If the damper door is stuck in the open position or broken, the refrigerator temp will not be controlled and freezing can occur in the refrigerator compartment.
Apr 01, 2014 | KitchenAid Refrigerators
Too cold in refrigerator Compartment
Check and clean the condenser under and behind the unit. check it's not accidentally been put on fast freeze mode. If all else ok, suspect thermostat faulty
Apr 22, 2012 | Frigidaire PLHS267ZA Side by Side...
Freezes everything
check the damper vent door that throttles cold air into the refrigerator compartment from the freezer compartment,ifd its frozen or stuck or even broken it cant close to keep cold air out of refrigeerator compartment when it reaches the temperature you set it at
Feb 22, 2012 | Avanti Refrigerators
I have a model BX21/BC21 and the refrigerator compartment is freezing some foods. What is desired setting for refrigerator compartment and freezer compartment for this model?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 30, 2011 | Amana Refrigerators
Refrigerator compartment freezing
May 25, 2009 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
Oct 02, 2007 | Refrigerators
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
