SOURCE: VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
SOURCE: ASUS A6 Series Entertainment Notebook VGA, Modem & Audio Devices
Check out this link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Just select your exact model.
Hope this helps.
SOURCE: no picture when vga cable is connected
Most tvs can only handle a couple resolutions (ie 640x480) through the pc input. Even some HD tvs can only do 480. Check that your video is turned on and setup to the acceptable resolutions.
right click your desktop
go to properties
click settings tab
click on the 2nd monitor
make sure the box is clicked at the bottom
"extend my windows desktop onto this monitor"
instructions for windows xp
SOURCE: Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
SOURCE: i cannot get my netflix movie to play on my vizio flat screen tv
There is a key that looks like a monitor, It may have to be used with a FNC or CTL key (look at the color - matches the FNC or CTL color. It should go laptop, tv out, both, laptop, tv out, both etc as hit it.
Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
