Question about Honda Maxus Pressure Washer MX5222
No pressure from the machine, i alredy cleaned the hose, the machine is making unusually loud crashing noises. i put oil, gasoline, everything is good but there is no pressure from it. how can i repair this and where can i go to get this repaired.
  • firehead May 11, 2010
    What model is it and what engine is on it?
2 Suggested Answers
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
Why does 835 make a loud noise when sewing?
Is it a mechanical machine? Most mechanical machines make louder sounds when they have not been oiled for some time. Consult the owner's manual and use ONLY good quality sewing machine oil.
Feb 16, 2016 | Husqvarna Sewing Machines
JX2517. Why is hand wheel stiff and machine not sewing properly?
The owner's manual states in the Maintenance section (page 34):
"In order to prevent damaging this machine, it must not be oiled by the user...
If problems occur, such as difficulty turning the handwheel or an unusual noise, immediately stop using the machine, and contact your authorized dealer or the nearest authorized service center."
Sep 01, 2015 | Brother Sewing Machines
Water entering machine but drum will not turn or start
Does the water just keep filling up, or does the water shut off after filling to a normal level?
If it just keeps filling, then your pressure switch or the hose leading up to the pressure switch is bad.
Does it make any unusual noises?
Oct 18, 2014 | Washing Machines
Knocking sound when starting up truck after sitting for a while
About the only thing you can try is to change the oil and filter to eliminate gasoline contaminated oil. Try starting it up and if the same noise persists, have a mechanic put a gauge on the oil sensor port to measure oil pressure with a analog gauge.
Excess bearing clearance will result in noise and allow oil to bleed down from the bearing caps. There are a few additives which are suppose to coat the engine parts and the coating is suppose to stay on overnight to prevent "dry" starts.
So if the oil pressure is low, the oil pump may be weak, but if the oil port tests normal, bearing clearance is excessive somewhere and the engine must be disassembled to find the worn part.
Jun 17, 2013 | Ford Expedition EL Cars & Trucks
Lower filter repair to eliminate excess noise
I'm sorry to hear your DC18 is making an unusual noise. Please note, the filter located beneath the clear bin is designed to last the lifetime of the machine, and does not need to be maintained or replaced. Attempting to clean this filter is likely to cause damage, so we'd strongly advise against this.
Although I note you've already cleaned the filter located inside the cyclone pack, you might want to take a look at the video below to check you've done so as recommended. In normal use, this should be done at least once every 3 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely somewhere warm before replacing it.
You may also want to run through the troubleshooting steps shown in our Support guide to make sure there are no obstructions you may have missed:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If your machine continues to make an unusual noise, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Apr 08, 2012 | Dyson DC18 all floors Bagless Upright...
The washing machine no longer works. It just has a loud buzzing noise when you turn it on.
If the humming noise is coming from the water inlet valve . Shut water of remove hoses clean the little screens inside valves make sure u put them back as they r in the unit for a reason.put hoses back on and turn water on give it a try.....Good luck
Feb 01, 2011 | LG Washing Machines
No water , when running, loud pulsating noise
Usally when there is no water comming in it is the water inlet valve. First turn selector swith to see if it is only hot or cold water that is the problem. Take the hoses off the back of the washer and make sure that when you turn the water on that there is lots of water pressure comming out of the hoses. If ok. its probably the water inlet valve. There are two screws holding the valve from the back. Access the valve. Remove the fill hose from the valve. Remove the four wires off the valve and put on the new valve. Reinstall fill hose and install valve with two self taping screws you took out. Put your hoses back on and your ready to go.
Dec 22, 2009 | Kenmore Washing Machines
6 Cyl 1998 Toyota Camry Oil Pressure Light
these cars have problems with bad oil pressure warning switches you may have someone put an oil pressure gauge on the car and make sure your pressure is within spec and go ahead and change the sender if it checks out please rate -jeff
Sep 01, 2008 | 1998 Toyota Camry
We have a GE Dishwasher, when it is in the washing mode, it makes a rumbling noise that is coming from the bottom 0f the machine. Can you help? Thanks
Make sure your spray arms are not loose first.If it remains loud you may have something caught in the food shredder area that is making motor strain/rumble.Also make sure to look under the machine to see if anything(water line-Drain hose) is touching the motor which will sometimes make some unusual sounds.
May 19, 2008 | Dishwashers
Honda Maxus Pressure Washer MX5222 Logo
247 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
