Question about RCA Televison & Video
Hello, I turn on my RCA 61' rear projection television. On the screen pop up PO 1.22 VO . What is wrong with the televison set?
  • keith_kathea Aug 02, 2009
    also the screen is grey.
premtech
  • 934 Answers
SOURCE: 61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Posted on Jun 14, 2007
techman
  • 3130 Answers
convergence power supply problem
Posted on Jul 01, 2007
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
Mine blinks like 5 or 6 times - picture goes out, but sound stays. It has been at the repair shop for 1.5 months and the tech finally sees the problem. He says 3 new tubes will fix it, but the blue is discontinued. Can anyone confirm?
Posted on Dec 14, 2007
my tv has the same problem but it blinks five time with no picture but good sound
Posted on Aug 01, 2008
freetek
  • 5568 Answers
SOURCE: rca 61" televison comes on for a few mins, get turns off
Sounds a lot like a thermal effect.
Buy a can (or maybe two) of freeze spray from an electronics supply company; figure on $5-6 per can.
Open the back of your set and look for a board with larger components on it and fewer small parts; this should be the power supply board. Either enlist a helper or (I prefer) use a mirror so you can see the screen. When the streak appears, hustle behind the set and spray selectively individual components on that board. If you can influence the line, repeat the treatment in a smaller area until you are fairly sure which one is temperature sensitive.
If the component is marked with text, record it. If it is color-coded right down the colors starting from the end closest to the first band.
If you don't want to learn a new skill, namely soldering, you could remove the board and bring it to a repair shop and let them know what to replace.
If you don't find anything sensitive on that board, the problem is going to cost more. You will have to repeat the same procedure using the spray on other boards until you have isolated the trouble area. If you can't single out a specific component, it will have to be sent to one of those 'factory authorised' repair places since failures of parts on the main board will have to be sorted out and then the board will have to be tested in operation and only that kind of repair facility will have the right hardware to do it.
Posted on Dec 04, 2008
I have a RCA 61" hdtv. i heard a loud pop and the screen went black. is this an easy fix?
see if you have a standby light on. if not then check fuse. if so then i would say this is not an easy fix.
Nov 10, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
I have an RCA rear projection TV with a dead fly behind the screen, how do I get it out?
pop the speaker grill off, then take out the 1/4 inch screws and remove the screen, if it's behind the screen, simply brust it away, if it's between the 2 screens, then you must take them apart and remove the body. also while your in there, clean the lenses and mirror with some windex, this will greatly improve your picture.
Sep 08, 2009 | RCA P61940 61" Rear Projection Television
PLEASE HELP!!!
Hello yvettegarcia,
You can try, but the problem is it won't work, you can join the two with clear glue, but the seem will show up in your picture, very much the way a patched screen displays the repair seen when it has been repaired. I would suggest getting in contact with RCA and ordering a new screen.
I hope this helps,
Thank you,
Shuttle83
Jul 16, 2008 | RCA P61940 61" Rear Projection Television
T V
That model is famous for the flyback going bad without warning and thats a good chance on whats wrong with your set.
May 05, 2008 | RCA P61927 61" Rear Projection Television
RCA 52" Mdl P52939, PTK195S16B
but there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Aug 11, 2007 | RCA P52939 52" Rear Projection Television
Rca d61w130yx1 61 rear projection
these rca sets have a processor that will shut it down it has a problem. red screen indicates yes.. it possible a red crt...difficult to replace. and expensive if not under warrenty. around 200 just for crt plus labor.... sorry
Apr 28, 2007 | RCA D61W20 61" Rear Projection Television
RCA P61927 61 in Rear Projection Television
Hello, Replace U14501. (Maybe) Best regards, Arpi
Apr 22, 2007 | RCA P61927 61" Rear Projection Television
Rca 61 inch tv
that "pop" was the flyback transfor, a resistor, or a capacitor bloweing up. if your not a technician this is considered a circuit repair and ther are no serviceable parts inside this set for you to replace without the proper tools , service manuals, and schematic diagram. Sorry man your gonna need a serfvice pro to help ya with this repair. Good Luck
May 24, 2006 | RCA P61927 61" Rear Projection Television
Televison & Video Logo
66 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
