Question about Refrigerators
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Kitchenaid refrigerator mdl KTRS22M has water in the bottom under the veggie drawers! There is some condensation on a little housing located on the top panel of frig section.
  • m1xf1 Aug 02, 2009
    Thank you rollpoll. I may have marked you not helpful. What I whated to say was this model does not have a drain hole under the veggie drawers. I did notice some droplets between the freezer unit and frig. Another thing is that the drain tray under the kick panel hasn't had water in it for some time. It has dust balls, rust marks and anything that crawls under a frig. Full mdl number is KTRS22MAWH10 Kitchen Aid.
    Novelist:
  • 116 Answers
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Posted on Aug 02, 2009
  • Martin Roland Williams Aug 04, 2009
    Hi, there's a drain, for all ref. i think you're looking in the wrong place, it is not under your veggie drawers, drain should be at the back, few inches above veggie drawers cover, that's why there's no water in your condensation tray, there should be, whenever your ref. self defrost, the water that settle under your veggie drawer, should be in condensation tray underneat ref. where it is dried up by heat, from compressor, fan and condenser. you have to look properly, it's better to remove your produce and bottom shelves, to have better look, sometimes foreign matter like, small pieces of food, anything could block it up, it's very simple, you just have to know where to look. good luck.
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Where is water comming from found in bottom under veggie drawers
often a blocked drain. The drain pipe should empty on to a collection bowl on top of the compressor. If you can blow sharply up this pipe, the blockage should clear.
Apr 29, 2012 | Samsung RS2630SH Side by Side Refrigerator
Subzero 650 bottom freezer is pooling water under the veggie drawer
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero 650 / O Bottom Freezer...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water collecting under veggie drawers on bottom
check to see if defrost hose is clogged under veggie drawers
Aug 02, 2009 | Kenmore Refrigerators
Water accumulation under vegetable drawer model KTRS22M
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Jun 17, 2008 | Refrigerators
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
326 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
