Question about Nitro BMW-482 Car Audio Amplifier
What makes a nitro 1200 watt amp go to protect mode
  • Nitro Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. what makes a nitro 1200 watt amp go to protect - makes-nitro-1200-watt-amp-go-protect-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Posted on Dec 18, 2014
    Top Expert:
  • Nitro Master
  • 76,691 Answers
A short circuit in the speakers or the wiring to them.
Posted on Aug 02, 2009
    Problem Solver:
  • 14 Answers
Under powering your subs and overheating your amp or postive and neg speaker leads are touching and ifyour running it bridged then your really making the amp heat up. and also try putting a larger gauge power lead and shorten you ground wire to 16 inch or less and uping the gauge wire also could slove the problem ,power and ground are the most importiant thig for your stero you need addiquet power and ground for your amps.
Is two comp 12's with a 1200 watts nitro amp a
The 1200w rated for the amp is usually an absolute maximum output, the rated output is more likely about a quarter of this figure (300w) I think for the subs you are looking at, you would be better off with a more powerful amp
Hope this helps
May 06, 2011 | Kicker Car Audio & Video
I have a nitro 1200 watt amp that was working great until it a red light that read " protection mode" turned on
Definitely is worth .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1200-watt-amp-working-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Aug 25, 2010 | Nitro BMW-482 Car Audio Amplifier
How should i wire my sub
if your amp has a bridge do nt bridge the subs just connect them normal planet audio subs usually dont have a high potential to withstand too much watts even if the subs say 1200 watts thats not true nwatts check the box the subs came in it will tell u true wattage it may say rms
May 24, 2010 | Nitro BMW-481 Car Audio Amplifier
What size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
I have a nitro 1200 watt amp earlier today it was workin with no problems we parked then came back in the car 3 hours later and it wasnt workin wont come on or anything just red light which is protecting...
Check your speaker wires, make sure everythings connected right with no short circuits, and check all of the fuses in the amp, and make sure none of them are blown. If all this checks out just check the battery wire, grnd, and remote wires. It has to be a wiring issue unless you busted your amp, but if was working when you tuned it off it should be alright... hop this helps...
Sep 10, 2009 | Nitro BMW-484 Car Amp
Nitro BMW 484 1200 watt amp.
check fuses and remote wire at the head unit. must have a good ground at amp.
Dec 03, 2008 | Nitro BMW-482 Car Audio Amplifier
Mmat amp 1200 watt
If the amp is in protect mode, it probably has shorted output transistors.
What model amp is it?
Aug 20, 2008 | Car Audio & Video
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Nitro 2,000 watt amp
Maybe the audio amplifiers IC's are in bad conditions you need to replace them.Good luck.
Jun 02, 2008 | Car Audio & Video
Amp in Protection Mode
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 19, 2007 | Nitro BMW-482 Car Audio Amplifier
Nitro BMW-482 Car Audio Amplifier Logo
575 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Michael Kovalik III
Michael Kovalik III
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
