Question about Dryers
Water light still showing ,also blowing cold air
    Brigadier General:
  • 4,088 Answers
Assuming that this not a gas dryer. Check the dryer pair of breakers in the house electrical panel--push OFF, then ON. If breakers immediately re-trip, then there is a short to ground within the dryer case--usually the heating element.
Posted on Aug 02, 2009
What is causing my car to blow cold air from heat. them it over heats while blowing cold air when hot air does blow car runs fine no overheating please help. 2000 Monte Carlos 3.4
more than likely your losing cold water from your water system, make sure your water pump is up to scratch...sounds strange, but you need cold water for heat through your air conditioning...
Jan 21, 2015 | Cars & Trucks
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
98 chevy cavalier...water is boiling out of the overflow lid...it is plastic and that is where the radiator cap is. car runs hot, and water is gone when i get home...15 min commute. fill it up and...
sounds like it's time to take it to the shop and change head gasket if head is still good ! every time it gets hot it warps it, prob. need new head too !
Nov 11, 2012 | 1998 Chevrolet Cavalier
2004 toyota celica will not blow hot air for twenty minutes
If the engine temprature does not reach the normal level as it used to, it may be the coolant thermostat.
Iif it does, it could be air diverter gates not working properly, cold air blowing at a a light could point to that. The diverter gates are located under the dash.
It also coul be the valuve that controls the water to the heater core, but unlikely cause of the cold air at a light.
Jan 11, 2010 | 2000 Toyota Celica
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Heater only blows cold air
Yes,it rules it out. The valve leading the water into the heater core is not opening or the door that put the air past or through the heater core is closed. This is general information not specific to your particular model.
Dec 18, 2008 | 2004 Suzuki Verona
Dryers Logo
Top Dryers Experts
