Question about Sharp XR10XL DLP Projector
Lamp does not come on
Our church purchased this sharp projector in 2006 upon turning it on last week it would not light up. We are in the process of buying a new lamp but was wondering if it could be something else. also we misplaced the manual and need a new one.
For the time being at least, I got my projector back on by unplugging the power cord for about 30 seconds then held down the following keys on the projector: Menu, Enter and the Down Arrow and while holding them down, pressed the power key. The projector started up like new with H0000 hrs on the screen like it was a new one. Will be interesting to see how long the bulb lasts! I had been getting a Replace Bulb messge for several weeks before it shut off with two red lights lit. So I tried the above procedure befoer buying a new bulb.
Posted on Dec 23, 2009
  • 11,896 Answers
It is most likely the lamp.
Copy and Past this link in address bar for manual:
www.sharpusa.com/.../pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
Posted on Aug 02, 2009
I just installed a new lamp and now the stand by and lamp light are on and the projector isn't functioning although there is power to it.i guess what im trying to say is the projector isn't doing anything.
Posted on Oct 28, 2010
Lamp 1 light is on upon turning power on. Then lamp 2 light turns from green to red
it might be a bad lamp. i'd recommend reversing the 2 lamps, and if the problem follows, then you know you have a bad lamp.
May 31, 2011 | Sharp XG-PH70X Projector
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp...
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
Jan 27, 2010 | Sharp XR-11XC DLP Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Sharp XGE3500 Projector won't stay turmed on
the power supply is starting to go. the caps are drying up. if there is a large drain of power (like striking the lamp), it'll shut down.
Mar 02, 2009 | Sharp CLMPF0046DE10 Projector Lamp for...
Sharp XG-NV2U projector not firing up
there is a fuse in the block where the power cord plugs in. you have to disassembe the unit and remove the circuit boards to get to it as far as I can tell. the fuse is a 250volt 5amp ceramic fuse 20mm. I have the same problem and just found the blown fuse but I am still looking for the replacement fuse to buy.
jeff
Jan 08, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
XR1X sharp projector
reset the lamp timer (hold down menu, down arrow, and enter buttons, then power on).
Aug 17, 2008 | Office Equipment & Supplies
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Sharp XR10XL DLP Projector Logo
409 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
