Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv shut itself off while I was watching.
I tried unplugging and replugging power cord; that didn't help. Still no picture, no sound.
Standby light blinks two times, over and over.
The Sony Trinitron WEGA is six years old. Is it time to junk it for a flat screen (hope not).
  • 11,896 Answers
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Posted on Aug 02, 2009
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
My 36" Trinitron standby lite just keeps blinking..
Hello Nicrod,
Can you let me know how many times that light blinks on your TV? There would be a small interval between blinks and then big interval.
May 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Continuous blinking standby light
according to the manual try unplugging the cord and waiting 5 minutes then replugging and trying again. If that doesnt help you may want to check the bulb as they have been known to shatter
May 13, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
454 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
