Question about Whirlpool LER2614JQ Electric Dryer
Drum won't turn
Smells like a snake crawled up into the motor and my son turned it it hums and drum won't turn...anything special I need to worry about  before I get in there? It's unplugged.
Heats but will not tumble, I think I need to replace the belt. How do I get to it, I do not know how to remove the front of the dryer!
  • 213 Answers
Re: Drum won't turn
If your lint screen is on top of dryer pull it out and remove the 2 screws under it. then there are 2 clips under the front edge of the top. with a putty knife you can press the clips to raise the top. after top is up look inside on the right and left top part of the front of the dryer there is a screw on each side should 1/4" or 5/16" head. remove thoughs screws and front folds forward and lifts up to be removed.
Posted on Nov 25, 2007
0 characters
3 Points
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
When dryer is turned on , it hums but the drum doesnt turn. It smells like heating element is working, belt is on correctly but drum will not turn. Any suggestions? Thank uou
sounds like the bearing the drum rides on is bad. that will cause the breaker to trip as the motor strains to turn the drum on the bad bearing.
Sep 09, 2009 | Dryers
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
I press the start button and hear an electric humming noise and the drum does not turn.
unscrew the rear panel of the dryer,
You will most likeley find the rubber drive belt broken and wrapped around the drum or motor.
if so
Take your make and model details to your local parts dealer and pick up a new belt, for a few $
like a fan belt it installs snaked around the drum, motor, and backwards around a tensioner
May 29, 2008 | Frigidaire Dryers
Drum won't turn
not really, it may only be a little effort to figure out how the new belt gets wrapped onto the tensioner pulley...the broken one is surely on the floor coiled up under the dryer like a dead snake....don't's dead.
Oct 31, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool LER2614JQ Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
