Question about Pentax ZX-50 35mm SLR Camera
Mirror sticks in the up posit, and advancing process does not work.
    Brigadier General:
  • 11,967 Answers
My mirror contacts a kind of foam substance on the upswing. It got sticky a while back and I had the same problem as you. I dampened a cotton swab in rubbing alcohol (91%) and rolled it back and forth many times over the foam. Let it dry and my mirror doesn't stick any more. Might work for you.
Posted on Aug 12, 2009
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Jun 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5600 maintenance reset
Use # * C * to access SIM mode.
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
sensor.
Jan 29, 2014 | Sharp AR-5316 Advanced Digital Imager...
Mirror is locked open
Unless you have experience repairing cameras, this is not a DIY fix. Take your camera to a reputable camera shop and have a trained professional look at it.
Feb 03, 2012 | Pentax ME Super 35mm SLR Camera
I am unable to view through the viewfinder. I have taken out the film, and I can even fire the shutter, and the view finder is still black. I removed the lens and the issue is still there. Any help would...
is the mirror stuck in the up position? if so the rubber bumpers have become sticky. try to ( gently ) pull the mirror down it should fall freely, then clean the mirror with alcohol. you may have to remove the foam rubber bumper to prevent the mirror from sticking again. the mirror mechanism will work without the bumper just fine.
Aug 01, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Mar 16, 2009 | Minolta X-370S 35mm SLR Camera
Mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Feb 21, 2009 | Ricoh XR-10M 35mm SLR Camera
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Meade LX200R 12" Mirror Lock
The 'lock' is a ring gear that closes a ferrul against the draw tube to restrict its motion. It is not intended to be a hard lock. Try the Meade Advanced Users Group for further tips.
http://www.mapug-astronomy.net/
Jan 20, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Film Advance Will Not move
Hi,powerpe. The mirror release rod can be located in the bottom of the body once the plate has been removed.(there are three screws on the old k1000's) There is a gear train on the left side when viewed turned over.The mirror cockong rod is towards the rear and a little right of the main shaft.You might need to move a little silver pawl with a pin or micro driver then you can push the mirror **** in to release the reflex mirror.the mirror cocking rod is about 1/8" dia.Hope this helps
Oct 21, 2007 | Pentax K1000 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Pentax ZX-50 35mm SLR Camera Logo
213 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
