Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Old lady does not have the power in arms to start the lawn mower,
I can't seem to find the strengh to start the lawn mower, chain saw, weed eater, and all the pull starts I have now. Not an option to buy new and we just moved to a farm in Wy. Are there conversion kits available? Any help is appreciated. Thanks
    President:
  • 1,865 Answers
Unfortunately, there are no conversion kits available. At best you will have to find a handy person to make something for you.
Posted on Aug 02, 2009
My Ryobi weed eater the head of the weed eater is hard to turn and the engine doesn't want to turn it
problem most likely is that the cable drive for the head is twisted up inside the tube and jamming the operation
you have 2 options
remove the head from the tube and pull the cable out or
remove the tube from the power head and pull the cable out that way
new cables are available from your local mower shop
if the cable guides inside the tube are damaged , consider replacing the bent tube with a straight tube , then you can use more attachments for the head
Sep 20, 2016 | Ryobi Garden
Tip
Things to consider before trying to Start a Chainsaw, Gas powered blower, Weed...
When starting a Chainsaw, Gas Powered blower, Weed eater or Lawn Mower; here are a few things to keep in mind.<br /><br />1. Does it have a priming bulb? If so pump it 3 or 4 times before trying to start.<br />2. Do you have the choke pulled out or pushed down? <br />3. Is the Chain brake engaged? <br />4. Is it turned on.<br />5. Do you have it flooded? If so let it set for a 5-10 minutes and try again.<br />6. Do you have gas in it? Most saws recommend a 50:1 ratio. That equals a 2.6 oz of mixing oil to 1US Gallon of mid grade gasoline. <br />7. On bigger saws there is a decompression button located on the top, make sure it is pushed in. <br />8. While the choke is pushed down/pulled out, crank the engine until it "hits". On some saws, after it hits the choke will automatically go back in, but for the ones that don't manually push it in or up, then crank it again. It should fire. <br />9. On Poulan brand saws the choke is a little bit tricky on getting pulled out. It actually pulls out and up. You should fell it catch. When pulling it out and you think you have it out correctly, let off pressure from pulling it and see if it retracts back into the housing. If so, you didn't have it set right. <br />10. On mowers, do you have the blades engaged before trying to start? Mowers with a PTO button the engages and disengages the blades, pull up on the knob to disengaged. <br /><br />Finally, I know someone may look at this and be saying to their selves, "do you think I don't already know this?" Well, you would be surprised at how many items get taken to the repair shop and the mechanic find out it was one of the simple steps above as to what caused the item not to start. Most mechanics will charge an hours labor fee just for a one minute fix. The labor fee can range from $10-$40/hour depending on the small engine shop.
on Nov 15, 2010 | Garden
HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
Weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Replace starter line on my Poulan 446T PRO Weed Eater
Its quite a job to get to the starter, you need to remove the tube and shaft from the motor, then remove the tube housing held with three screws, once removed you will find the clutch, remove the securing nut clutch and washer, now remove the screws holding the clutch housing and remove, the starter pulley is housed in this housing.
Oct 10, 2017 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
94 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
