My washer will not fill. The water keeps running and it never fills and just drains out the drain tube.
    President:
  • 1,776 Answers
Check and see if the height of your drain is right. Sometimes if the drain is too low, it will cause the water to just flow right out of the machine. Check out the attached photo. Hope this helps and best wishes.
Posted on Aug 02, 2009
My 7kg Electrolux front load washer keeps stopping from between 1 to 14 minutes before it finishes. I have to keep coming in to press restart button. It keeps saying ERR 10. What does this mean?
Family alarm code E10 means difficulty in filling during wash phase or water leakage.
Could be:
E11 - Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty.
E13 - Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve is faulty; Water circuit on pressure switch is leaking/clogged; Pressure switch faulty.
Dado
Jan 03, 2018 | Electrolux Washing Machines
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Water keeps filling but will not start cycle.
The top load washer utilizes a pressure switch attached to a clear plastic hose. If the water fills the tub but will not stop filling you will need to remove the top panel and inspect the hose for obstructions. You may need to disconnect the tube flush it clean and make sure no foreign debris are in the connector on the pressure switch. If the tub will over fill, you may need to replace the pressure switch. If the water will not fill the tub and the water continues to run you need to check the drain pump. Is water exiting through the drain hose? If so the drain pump could be the problem.
Feb 23, 2011 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Washer keeps filling up with water and it will not stop
the main drain hose may be stuck to far down inside the drain tube.if the machine is not over flowing and flooding your plaace.then pull the drain hose up to the level of the control head.with the machine off,you should here water running out once that has stopped restart your washer put keep the hose up and it should stop filling when it gets full.
Sep 19, 2009 | Washing Machines
My washer will not spin and can only fill tub on small loads cause water will run out
does the water keep running and it keeps draining the water? if so your drain hose needs to be higher than the highest water level in the tub or it will drain as it fills.
Aug 31, 2009 | Washing Machines
Washer will not fill up with water...runs right back out of drain tube
Make sure the drain pipe is at least 34 inches above to bottom of the washer and that it is not sealed at that point. This will prevent siphoning.
May 26, 2009 | Maytag Washing Machines
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
The water keeps running and it does not fill up.
If there is no water on the floor, it would have to be that the water entering the washer is going through the drain tube because it is too low, or for some odd reason the drain pump could actually be running, pumping out the water as its entering the washer. If there is water on the floor, there could be a leak anywhere along the drain tubing, the drain pump itself, or even the drum/basket seal.
Mar 13, 2009 | Frigidaire FGX831CS Top Load Stacked...
Washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
May 11, 2008 | Washing Machines
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
