Metal noise and rattling during washing cycle only.spin cycle is fine and normal.just started doing it in the middle of the wash cycle. guessing 10 to 15 years old on washer with never having a repair(how about that)wpse4270 first thing came to mind was bearings.5 kids and we run it all the time.what can i check for?scott
    Brigadier General:
  • 4,088 Answers
If top loader, remove the agitator and try to move the shaft sideways in a number of directions. If sloppy, the shaft and bearing need to be replaced. To get at it, the top of the case must be open, unbolt the inner tub, then the outer tub. Be careful around any rubber seals at the bottom.
Posted on Aug 02, 2009
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
