Question about Sanyo Televison & Video
I have a Sanyo AVM-3256 32" tv there is no sound and I have checked the speakers the speakers are fine I dont know what else to check
    Novelist:
  • 183 Answers
Is there an audio jack socket at the back? If there is try plugging in an hi fi and see if audio is available. If it is, the problem lies in the audio power amplifier section of the circuit board. With a voltmeter, check that the audio amplifier chip has a supply voltage to the chip. If it has, at the right level, you will need an oscilloscope to check the input signal to the amplifier. Or simply gently tap the input with a screwdriver and if you have a crackling noise from the speakers your audio amplifier chip is ok and the problem lies further downstream.
Posted on Aug 02, 2009
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
Sound wont come on, picture fine, but no sound
Sound circuit problem. Check speaker. Contact service center for assistance.
Apr 22, 2010 | Sanyo AVM-3659S 36" TV
We have perfect sound but only a thin horizontal line in the middle of the screen.
this is a capacitor that has gone bad in the vertical delfection stage of the tv. it is an very easy and cheap fix if you know someone who knows how to solder and replace electronic components. If not then you'll just have to get another tv as taking it into a tv repair shop is not worth the cost. You could get another tv for what they will charge you to repair it,
May 31, 2009 | Sanyo AVM-3659S 36" TV
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sep 27, 2007 | Sanyo AVM-2506 TV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Mar 04, 2007 | Sanyo AVM-2506 TV
No picture,no sound,blank
This set is very popular for the capacitors to dry upa and go bad in the main SMPS as well as the switching power supply. If you have no know how on how to test capacitors or solid state electronics please take the set into a repair shop for an estimate
Jul 28, 2006 | Sanyo AVM-3659S 36" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
