Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The washer turns on, fills with water, then stops. Agitation won't start unless you slam the lid or sometimes if you "nudge" the setting forward and then pull out and then in.
    President:
  • 1,865 Answers
Sounds like door switch may be failing, or the wiring between door switch and timer has loose connection. You can replace the switch or check ther wiring, or bypass the door switch circuit by jumping the leads at the timer
Posted on Aug 02, 2009
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not go pass the wash cycle to spin or drain
There is at least one safety switch activated by the lid.
Depending on machine construction, these are somewhat exposed to water incursion that eventually causes them to fail.
The slamming of the lid is causing the failing switch to make enough contact to allow it to spin.
If you are lucky (I don't know your machine), these may be located toward the rear of the housing where they can be fairly easily replaced.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Water fill stops
Your lid switch is probably damaged or loose. Examine the lid switch on the right-hand side of the washer tub opening. There are two screws that hold the switch in place. Check to see if they are loose. In addtion, the lid should have a small plunger that depresses the switch when the lid is closed. Make sure it is intact and not broken. If the switch is tight and the plunger is intact, the switch has probably been damaged and needs to be replaced. If you have the type of washer that has no visible plunger and/or switch, the lid switch is locate in the rear on the left hand side and has a small arm attached to the lid that activates a contact when closed. Often this arm can get bent and will not engage the lid switch contacts. A simple adjustment (sometimes) can correct this. I've seen a lot of these switches where the casing on the switch separates and the contacts will not close. Slamming a washer lid is highly NOT recommended just for this very reason. The switch is an easy replacement and costs roughly $35. If youy post back with your model number I can research to find a part number for you. I will also give you step-by-step instructions on how to replace it. I hope this helps.
Oct 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
269 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
