Question about Sharp AF-S120EX Air Conditioner
Very loud - appears to howl - sounds like bearings on fan motor- have it tore down - can motor be oiled or repacked bearings?
    Novelist:
  • 166 Answers
Careful: Some AC's are not designed to be oiled again once it leaves the manufacturer (while others do as) as to speaking of motors of ACs.
If your AC is making that kind of noise-racket, your AC is experiencing a loose part that needs to be re-tightened.
If it's specifically making a "rattling sound," like it says in this diagnostic article of a handyman site says, then it is likely that your AC fan is loose:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
In either instance, your best bet is to contact an experienced AC technician/contractor, as the making of noise is a sign of a serious problem that must be fixed right away, unless you would like to experience almost certain irreparable damage to your AC in my opinion--when sounds are made that's because two or more parts are coming into conflict with each other, causing friction, and thus damage, to occur.
Get free estimates from local AC/HVAC contractors in your area who would be in the position to fix it for you (or whom you can rely on to get as much infromation as possible during the free-estimate consultation so as to apply the information for your own use). The rule of thumb is to get at least three estimates. Good luck!
Posted on Aug 09, 2009
When turn on blows cold air but makes loud whining noise like rubbing on something. almost a whine sound
sounds like your bearings are out on your fan motor. Some of the older fan motors have places where you can oil the bearings but most newer ones do not. Unless you have a place to oil the bearings and they are not already too far gone you best bet will be to replace the motor. Once the bearings start howling in the way you described it is time to start looking for a replacement. It is also possible (although unlikely) that the noise you hear is (a) the fan blade hitting part of the frame. (b) the bearings in the compressor.
Jun 05, 2011 | Heating & Cooling
Noise coming from fan motor
this could be a drive belt or a dry bearing what ever it is you should get it sorted out,,, pull the unit out and find out were the noise is coming from if its a belt replace it if its the motor, it may need new bearings as there sealed type you cant just swill it with oil as nothing will get to the bearings the motor will need to be striped down to fit bearings in it
Nov 06, 2009 | Samsung RS2578BB Side by Side Refrigerator
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud screeching sound from window fan.
There are two bearings in most motors.  One is at the base of the fan blade where the shaft goes into the motor.  Try lubricating this with a small amount of household oil.  If your lucky, this will stop the problem.  If not, the bearings have worn and the unit will need replacing.
Nov 15, 2008 | Honeywell HW628 Window Mount Fan
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Howling sound from freezer fan section
it is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Jul 05, 2008 | GE Refrigerators
Sharp AF-S120EX Air Conditioner Logo
357 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
