Unable to get windows media player to load songs onto a micro SD card for use in an LG cell phone. It keeps saying disk is copy protected. I ripped the CDs as MP3. Turned off copy protection. The switch on the SD adapter is off.
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
Got sd card and installed music from computer ,plugged into phone but when i go to music player it shows no songs on card, how ever when put back tocomputer songs show up and play
Your Samsung Hue can only play MP3 encoded files (extension mp3). If you have taken music that has been ripped using the windows media player, the default rip settings put the tracks into windows media audio format (wma) which your phone cannot read. You'll need to find a free wma to mp3 converter and convert your files to load onto your phone. You can also set Windows Media Player to default to MP3 when ripping under the Tools|Options menu item. Look under the RIP tab and change the default format to MP3. If you are already using MP3, it is possible that you are using to high of a Kbs rate on your MP3's in which case you'll need to be sure you rip tracks in a lower Kbs rate (also under the RIP tab in Windows Media Player). Here is a link to a free WMA to MP3 converter...
http://download.cnet.com/1770-20_4-0.html?query=wma+to+mp3+converter&tag=srch%3Ba&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows
Feb 01, 2010 | Samsung Hue (SCH-r500) Cellular Phone
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Envy2 itunes on sd micri card
You cant transfer your itunes on to it (legally). Itunes music is DRM protected. To put your itunes on your phone you could burn it to a CD, put that cd back into your computer and rip the music into windows media player (arguably legal) or you could get software that removes the DRM protection (illegal).
Mar 29, 2009 | LG enV VX9900 Cellular Phone
MP3 wont play in my LGkeybo
I have a Keybo 2 phone so I assume the procedure is the same for the first generation Keybo.
1) First of all, only MP3 format works, period. Don't waste time trying to load WMA or any other music format.
2) Get a micro SD card as this opens up other features of the media functions
3) Using the USB cable, connect your phone to the computer and there should be 2 file browsers that will show up: one for the internal memory and the other for the external memory (micro SD).
4) On the external memory browsing window you should find a MY MUSIC folder. Copy all your MP3 music files into this folder.
5) Unplug the USB cable and open your phone's music player. It will detect the new songs and build update the library.
There you go, you're all set! It took me a couple of hours of searching and tryouts but this works every time. Good listening!
Jan 18, 2009 | LG 10X DVD IDE 452000078
Importing music...
Now a days you are getting latest Mp3 players with Micro SD card fecility. Buy them and copy the mp3 songs from computer to Micro SD and shift that from mp3 player to your lg phone. This works fine.
Dec 18, 2008 | LG Vu CU920 Cellular Phone
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Wont copy songs to mp3 player because of write protection
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Under this menu, you will be able to choose the type of music file as well as the quality with which you would like to save the music.
  4. Make sure the box next to Copy protect music is left unchecked.
Your GPX player has the ability to play music files in both the MP3 and WMA format. Make sure to use MTP when transferring copy-protected WMA files.
-Tha Mp3 Doctor
Nov 04, 2008 | GPX MW3836 MP3 Player
LG KEYBO
There's 2 ways that you cn listen to music in your Lg Keybo.
1-Download songs from the Internet cell phone
2-Buy a Micro SD card and put all your song onto the card, and plug-in the card into the phone.
Im only a 8 years old, but I know how to solve problems too :P
Oct 29, 2008 | LG 10X DVD IDE 452000078
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
42 people viewed this question
 Grubhead
Grubhead
