Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Where do I find a magic touch whirlpool on/off switch for a 2003 jacuzzi espree series 660? Can I order on line? Thanks. huggybear522
  • dbmass Aug 20, 2009
    alanl3511,
    thank you for your response. yes it's the button that starts the tub, however i found a authorized service tech in our city who had the part in stock and all i have to do is put it in. again thanks much.
    best regards
    huggybear522
  • Alan May 11, 2010
    Is the button one that pushes in to start the tub, or an electronic button you press? There were two types.
    Scholar:
  • 80 Answers
Go to Jacuzzi.com and find the part number, then go to Guillens.com and find the part you need.
Posted on Aug 21, 2009
I have a Espree 536 and need to replace the magic air switch. The tub is enclosed with a tile mosaic front which I do not want to have to remove if at all possible to replace the switch.
it is possible that the switch is held in place by a nut from underneath
see if you put your hand up under the panel to see if there is a nut there
Oct 11, 2015 | Jacuzzi Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Our Jacuzzi Espree 6060 corner whirlpool stopped working after about 15 months of light use. I called the company and they had me order an air switch. Our motor does nothing. No clicking. GFI is working. I...
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
May 30, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Espree 7242 pump/motor will not shutoff. Manual says to reconnect tube to Magic Touch switch or to air switch pumpmotor. Do I have to pull the tub out? It sits in a tiled skirt.
There should be a removable panel either around the skirt or in the ceiling below the tub to access electronics and plumbing to repair.
Jan 09, 2010 | Tools & Hardware - Others
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
1,519 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
