Question about Sony PlayStation® 3 (80GB) Console
I have a sony model number KV27s65 tv with low audio. Need help in finding solution. The volume control is turned all the way up but the sound coming from the tv is low but clear.
  • ivan_rolle Aug 03, 2009
    I have a sony tv model number kv27s65 that has low audio. The volume control is turned all the way up, you can hear the audio but it is low and clear.
    Sergeant:
    Novelist:
  • 198 Answers
This may help:
http://www.fixya.com/secure/support/t239114-low_audio_output_all_sudden
if this doesn't work, the sound board may need to be replaced:
part number: SBX1637
Hope this helps!
Posted on Aug 03, 2009
  • 952 Answers
Thanks for using FixYa!
I personally have not noticed this issue on my PS3, everything has been working great.
I know that most games have a built in audio option where you can adjust sound fx, background music, etc.
Check to make sure that none has lowered these settings on you as they are saved when the game is saved and will not go back to normal unless manually adjusted again.
On the DVD playback side:
Press triangle during DVD playback, this brings up the options, such as chapter skips, repeat, ff, etc.
In here is an internal volume adjustment function for the PlayStation.
By Default it should be dead center and labeled as "Normal"
I find that this position is just fine but again someone may have changed this setting accidentally or purposely for whatever reason.
Adjust it as needed and see how things work out.
Have a nice day.
-HotRatchet
  • Jac Lawrence Pimentel
    Jac Lawrence Pimentel Aug 03, 2009
    This is a follow up solution.
    You can also try to go into the PS3 audio setup menu and change the output to 2-channel downmix. See if that works.
    -HotRatchet
I have a sony home theater system. my cable box volume is all the way up but still with watching TV the volume is so low, eventhough the volume on the sony system is set to "MAX". also i get a...
First, TURN THE VOLUME DOWN. We don't test with max volume any more than we start our cars with the accelerator floored.
How is the audio from your TV getting to the HTS? Name names and be specific.
Your TV audio output may be dependent on its volume control. Many TV's have a FIXED setting in their setup so you can lower or turn their speakers off while letting REAL electronics and speakers handle the sound duty.
OR, you could (and should) bypass the TV entirely as an audio source and go to the cable box's audio output.
Feb 05, 2011 | Audio Players & Recorders
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have a 1998 sony trinitron 27 inch television model no kv27S65. The picture in picture came on and I can't get it to turn off. Help! The info in the email is the correct model number not the info in...
You should have buttons on the remote for the TV which are SWAP and FREEZE and PIP. Pressing PIP should turn picture in picture ON and OFF each time you press.
Aug 13, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sound from tv very low
When asking questions that involve multiple units we really need to have make/model numbers and connection details of ALL the players in the scenario as each one has a role in the audio's pathing and control.
If the TV's audio section and speakers were superior to audio-specific componentry we own, why would we need Hi-Fi? Sometimes the audio from the TV is useful so we run RCA audio cables to the receiver from theTV. In some TV's the TV audio output is Variable according to the TV volume control or Fixed so the external electronics can have a contant signal.
In general, TV-related audio is best obtained directly from the source, not the TV. So your cable/satellite box should have its best audio connection going straight to the RCA unit.
Mar 24, 2010 | RCA RTD317 Theater System
No sound, No more
Sorry it took so long to reply, to your request for help. You need to use you owners manual and go to the section on audio controls. Check every function that can turn off the volume to the television while it is playing. Make sure all the controls are set properly for the use of the audio on the television. If you cannot find the problem and correct it this way, you can call the RCA customer support telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for their assistance. I hope this information helps you with your remote control problem. Thank you for using FixYa and have a nice day!
Oct 26, 2008 | RCA DIRECTV Satellite Remote Control
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony PlayStation® 3 (80GB) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
