Question about Kodak EasyShare V610 Digital Camera
Camera blanks out with message- error 45 and its not coming on
Have my kodak v610 a few years now- no problems until a week ago. while using the video it just blanked and said camera error see e#45 or something like that. it wouldnt shut down (the camera lens wouldnt close) so i had to remove the battery and such. anyways i checked the manual and did what they said- i erased all pics from the memory card. then i charged the battery. but the problem still persists. i tried taking a picture- it did 1 and then when i clicked review and back to camera it blanked again with the error. nothing is working. its just not coming on.
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Camera opens with optical zoom in mid range. Will not move to W..
HI! I HAVE A PROBLEM WITH MY CAMERA KODAK V610. WHEN I OPEN IT, THE LCD SCREEN APPEARED (CAMERA ERROR # E45 AND SEE USER'S GUIDE...PLEASE HELP ME HOW TO FIX IT...I LOVE MY CAMERA SO MUCH...I HAVE SOMETHING SENTIMENTAL VALUE FOR MYSELF....I KEEP IT FOR HOW MANY YEARS...I DON'T WHAT TO DO???? I LOOK FOR THE USER GUIDE IT WASN'T THERE...HOPE TO HEAR YOU SOON. THANKS
Aug 21, 2013 | Kodak EasyShare V610 Digital Camera
KODAK V610 MEMORY CARD STUCK
Try going into your setting and check the "QUALITY" settings. It may have defaulted to the maximum 6.1mp for images, and Quicktime for video. Also, you should have the option of formatting the SD card in the camera. Try these and see if it gives you a few more photos. With a card that size, you may have to take a step down in image quality to gain a higher number of stored photos.
Oct 23, 2017 | Kodak EasyShare V610 Digital Camera
I just want to know what it errore 45???????
Hello, The system error codes are for kodak diagnostic purposes only. just like you vehicle stores trouble codes for the tech to obtain info for locating system problems. Needs to be serviced.
Best Regards, Russell
Dec 13, 2012 | Kodak EasyShare V610 Digital Camera
Error 45
Hello, The error code 45 indicates that the camera needs service/repair. You need to take it to a camera shop for them to determine the problem.
Dec 09, 2012 | Kodak EasyShare V610 Digital Camera
Hello, I'm from Indonesia introduce doctoral pocket digital camera. to the problem of error 45 on kodak V610, V570, V705 caused by a focus motor carry. I often deal with the problem that I have about 430...
Error 45 usually shows up when there is a problem with the camera's lens. The camera locks up to prevent further damage. On some Kodak models, there is a notation in the user's manual that only says that the camera needs to go in for service.
So, what can you do? Try taking the camera and tapping the edge nearest the lens hard against your hand several times. This can dislodge any grit that might be jamming the lens. Turn on and test.
Clean with canned air. Using short bursts about 2 inches away and at an angle so as to blow any debris out instead of deeper in. Go around the lens turret and then test.
(At your own risk) set the camera on a tabletop and look at the lens to see if it is out of alignment. If it looks off center, push the lens toward the greater gap until you hear a click. Turn on and test.
If none of these work, then your camera needs to be physically examined by a repair technician.
hope this helps.
Feb 23, 2011 | Kodak EasyShare V610 Digital Camera
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
My camera error # e 45
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Sep 27, 2009 | Kodak EasyShare V610 Digital Camera
Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 18, 2009 | Kodak EasyShare V705 Digital Camera
V610 error 45 whatcan i do
i bought a kodak v610 a few years now- no problems until a week ago. while using the video it just blanked and said camera error see e#45 or something like that. it wouldnt shut down (the camera lens wouldnt close) so i had to remove the battery and such. anyways i checked the manual and did what they said- i erased all pics from the memory card. then i charged the battery. but the problem still persists. i tried taking a picture- it did 1 and then when i clicked review and back to camera it blanked again with the error. nothing is working. its just not coming on.
Jul 04, 2009 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
835 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
