Question about Kenmore 71279 Bottom Freezer Refrigerator
Fridge not cold, freezer fine...
Our fridge is not getting cold but our freezer is fine. We cleaned 10 years of dirt and dust out of the bottom but hasn't seemed to help.
  • 213 Answers
Re: fridge not cold, freezer fine...
Look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Posted on Nov 25, 2007
0 characters
3 Points
Samsung freezer not working light blinking but fridge is working
There must be lot of dirt and dust on the coolant tubes running from compressor in the rear. To solve the following.
Disconnect the refrigerator. Pull it out so you can access the rear bottom end of the fridge where you can go to the black compressor. You will find tiny tubes running on black flat curved sheets. Feel the tubes and clean the entire area with cleaning solution or water with a damp cloth. After cleaning and drying, connect the electricity and the fridge will work fine.
Sep 11, 2014 | Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
My freezer works fine, but fridge doesn't cool down below 55 degrees. Could it be the adjustment dial in the fridge.(i have cleaned the dust and dirt out of the back/bottom.
It sounds like the circulating fan is wearing out. The fan circulates air thru the freezer as well as the refrigerator. When it starts to wear out the force is reduce to a point that the freezer will get cold but the refrigerator will not get cool.The minimum cost of the assemble is around $300.00
Jul 10, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
My refridgerator runs but does not stay cold.
First you can try cleaning out all the dirt, dust and debris from around the compressor. Second try to recharge the freon in the unit. Third you can probably have the compressor tested it may be weak and neeb of replacement. In most cases it's cheaper to replace the refridgerator............
May 06, 2009 | GE Refrigerators
Freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Kenmore 71279 Bottom Freezer Refrigerator Logo
289 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
