Question about Brother MFC 240C All-In-One InkJet Printer
GIVE ME A MESSAGE TO SEE MY MAINTENANCE GUIDE. UNABLE 34.
I WAS PRINTING, BY MISTAKE I PULL PAPER AND GAVE A MESSAGE THAT READ SEE MY MAINTENANCE GUIDE. UNABLE 34.
Print unable 4F
Posted on Sep 06, 2009
Init unable 34 message
Printhead not moving. Check for any thing blocking the head or anything stuck.
Apr 10, 2014 | Brother DCP-J140w Compact Color Inkjet...
Print Unable 36. See troubleshooting and routine maintenance...
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Had paper jam now the printer says routine mantiance needed chapeter 34 trouble shootingg user guide (do not have guide :-) )
Usually, routine maintenance messages won't cause any problems.
Here is a link to the manual. There is a section on routine maintenance, but it isn't on page 34. Take at look at that and let me know if it helps you. I'll be doing the same. Please get back to me.
Dec 07, 2008 | Brother Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer not printing says to see user guide unable 34
i had this problem, paper was jammed in between printer cartrage and the right wall ( when lookin at it from front).
open top flap of the printer, u will have access to the cartrage (the thing that moves side to side whilst printing) move that to the left and have a look on the right hand wall. you should see quite a bit of paper jammed up in that area, make sure u clean throughly, get a torch if psooible, close flap then ure eon ure way
Sep 12, 2008 | Office Equipment & Supplies
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-560CN unable to print
did any of you three that have the prombelm try going into the files and turnig off all the periously loaded commands ? I bet this is the prombelm, cause the printer only does what it is told and if it is haveing and error message it is beacuse it is tuck in that command of left over printing comands and they haven't been erased yet try and see if this helps and get back to me lala linda
May 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Having unable to clean error message
your dcp needs a new waist ink tank (absorber).
Search brother homepage of your country for a service dealer near your home and buy an ink absorber. post here again when done. will give you the instruction then.
Jan 08, 2008 | Brother DCP-110C All-In-One InkJet Printer
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
780 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
