Question about Garden
Throttle linkage came loose from carburator, how do i remove the carb.? echo 14" cs-340 chainsaw
  • 154 Answers
2 very small screws
Posted on Aug 03, 2009
How to hook up choke linkage on new carburator
check out PartsTreeRepairClinic
Nov 24, 2017 | Echo Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Adjust the throttle on my echo cs305 chainsaw
Toni,
Can you give me a little more information on your problem. Are you having a problem with the throttle linkage or is it a carburetor adjustment question?
Dec 31, 2014 | Echo Cs305 Cs 305 Carburetor Intake &...
Where does the small hose on the carb go on the engine
f5f24c66-131d-46da-af84-447310da2d0c.pngConnects to the plug hole immediately to the right of the carb.
Oct 16, 2014 | Echo Chain Saw. 14 in. 32.6 cc Gas Chain...
I have an Echo CS-3450 model... The throttle trigger has become disengaged somehow. When I depress it, no reaction from the engine or bar. Any ideas how to fix it?
the trigger is connected to the carb with a linkage rod. it has probably come off. usually you will need to disassemble the saw to get to it. not a easy job. some times best to take it to a shop
Feb 12, 2011 | Echo Garden
Idle to high
Make sure the carburetor was re-installed correctly as any air leak between the carburetor and cylinder will cause high engine speeds but almost no power. It can also scuff the piston/ring(s) and cylinder due to very lean lubrication from the fuel. Hope this helps!
Jul 12, 2010 | Echo CS400 18" Chain Saw
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Need the carb setings for a echo cs-510evl
Your OM follows;
http://www.echo-usa.com/pdf/documentation/CS510evle_010186.pdf
Carb settings are on page 14.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 25, 2010 | Echo Garden
What are the adjustments for the high and low mixture screws on the carbureator? the carbureator is from an echo 500vl chainsaw.
Echo thinks your actual model number is CS-550EVL. Page 14 lists the starting points for carburetor adjustment here:
http://www.echo-usa.com/pdf/documentation/CS550evle_010186.pdf
Additional manuals for you saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
Once initialized this is the best procedure I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 13, 2010 | Garden
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
