Question about Kenmore Washing Machines
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
  • Anonymous Mar 16, 2014
    f25 error for kenmore elite he5t washer
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Posted on Jul 04, 2010
Sud appears, followed by F35
Hello & Welcome to FixYa
F35 error means that there is some sort of problem with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore Elite HE5t Washer
I get sud and then f35 code
The error code is do to a hose problem. Scroll down and locate error.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Jul 29, 2011 | Kenmore Elite HE5t Washer
Displaying f35 and sud how do i fix
F35 error code means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer is about 2yrs old. I am now consistently getting either "Sud" code or F35. Is there a part for the F35 that needs to be replaced? If yes, could you let me know as well as...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@$$
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
HE5t Steam shows SUD then f35. I have unplugged it. Plugged it back in; started a rinse only cycle and still it show this error. The washer is empty. I check the sensor on the back right hand area that I...
SUD means there are too many soap suds in the washer. Are you using a front load approved detergent? Are you using the correct amount? or slightly less is better.
May 12, 2017 | Kenmore Elite HE5t Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
1,181 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
