Question about Kenmore 98702 Stacked Washer/Dryer
Water all in laundry room floor
Did a load of laundry and 20 minutes later checked on it and it was setting in a foot of water
    President:
  • 1,776 Answers
Did the washer overfill or do did it leak the water out from somewhere? Typically, if the washer is overfilling it is caused by a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, pressure increases on the air in the tube and when it reaches a certain point, it activates the switch to turn off the water and signals the timer to agitate. Look for any obstructions in the tube and the switch can be tested for continuity with a multimeter. No continuity means the switch is defective. Hope this helped and best wishes.
Posted on Aug 02, 2009
I ran a rinse cycle on my washing machine (top load) last night. When it was done, I went into the laundry room, and there was water on the floor, in the hall and in the adjoining bathroom. The water was...
check your connections on your hot and cold water taps that connect to your machine check youy drain connection if all is ok then it is your pump
Feb 27, 2011 | Washing Machines
I put a load of clothes on to wash and left the laundry room and everything was fine. When I returned the whole laundry room floor was flooded! I can not see where any of the incoming water lines or the...
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
Jan 19, 2018 | Kenmore 24832 Top Load Washer
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
139 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
