Question about Cell Phones
MY TREO 650 WILL NOT START BACK UP AFTER BEING IDLE
  • braddunnllc Aug 02, 2009
    HOW DO I CHANGE THE SCREENSAVER ON MY TRO 650
    Brigadier General:
  • 4,090 Answers
Depending on the length of time it is idle it will do this. Some of the 650's mine included seem to discharge to the point that they refuse to come on wehen the button is pressed for on.
Timjke to move on, unless you are patient.
1) do not let the battery deplete to 100%
if it does connect it to the charger for a few hours and try again. Sometimes it still refuses to start. My additional fix was then to open the case remove the battery count to 50 and reinsert it. It would then reinitialize. Palm said the battery terminals inside the unit were damaged or dirty. I cleaned them and added some packing at the base of the battery and this fixed it for a while.But a repair will cost $AU180 in exchange of unit for a refurbished on
2) ise packing at bottom of battery to keep it against the terminals
cheers
Posted on Aug 02, 2009
  • 11,896 Answers
Do you have any screen savers on? This can eat of tons of memory. You may also need to have an update downloaded. You may be experiencing a firmware problem or glitch and needs update.
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Tip
HOW TO PERFORM A HARD RESET ON Treo 650
Performing a hard reset on a Treo 650will erase everything on the smartphone. Most people do this because of trouble with the Treo 650's software. There are several key stages to performing a hard reset. Follow these steps to learn how to do it properly.
  1. HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
  2. Step 2 Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
  3. Step 3 Let go of the red phone button when you see the Palm screen.
  4. Step 4 Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
  5. Step 5 Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
  6. Step 6 HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
on Sep 17, 2009 | Palm Treo 650 Handheld
Treo 650 freezing if idle for a few hrs
Maybe a button is getting stuck, or a component has stopped working.
Jan 01, 2010 | Palm Treo 650 Smartphone
Treo 650 keeps restarting itself
its prob'ly caused by an app which is not fully compatible with palm os.... remove your mem.card, and sim then, hard reset... thats what i did, my treo 650 kept on restarting after i installed gizmo.... try it and get back to me....
Dec 09, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Apr 24, 2008 | Palm Treo 650 Handheld
My palm treo 680 turns itself off repeatedly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
Buttons not working properly
hi dear
Good luck
Outlook Calendar synchronization failed in palm treo 650
hi dear
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
