Question about Dishwashers
Dishwasher is leaving soap spots on my dishes, do you think im overloading it or my sprayers are clogged.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
It is probably not soap and probably hard water. www.dishwasherfilter.com has a product out that filters the water going into your dishwasher. it is very affordable and guaranteed to work. your dishes will look amazing after one load.
Posted on Aug 06, 2009
  • 63 Answers
If you have soft water you're using way too much detergent. Use a powdered detergent only. Be sure the SPOT FREE RINSE well is full.
Posted on Aug 02, 2009
How do I clean the sprayers inside my Ge Nautilus builtin dishwasher? The soap in the dispenser is not fully emptying and at the end of the cycle is caked in the dispenser and leaving gritty residue over...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time. The system should also help clean the sprayers.
Jan 05, 2010 | GE Nautilus 24" Built-in Dishwasher
My glasses arecoming out with soap and water spots. I think the dishwashing soap has clogged up the washer/ sprayer arms. is there any cleaning solvant (eg CLR) I can use to clean out the washer
add rinse aid to rinse aid dispenser... that should help the spots.. as for cleaning the arms.. not really necessary... but you should pull them off occasionally and see if there is something stuck in the holes... i found rice in mine.
Dec 05, 2009 | Sewing Machines
Leaving gray white streaks and spots on dishes
Check the following to address this issue--
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
4. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 01, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
Ge dishwasher problem
Soap is not disolving because either your water temp. is too low (adjust at water heater).Or your sprayer arms are clogged up.(remove any particals that can be trapped in the holes on your sprayer) THATS IT !! PLEASE LEAVE A RATING !!!!!
Jun 08, 2008 | GE 24 in. GSD4000J Built-in Dishwasher
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher leaving dirty dishes
Buy a couple of bottles of dishwasher majic, run those through and make sure you are not using too much soap.
Dec 28, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
368 people viewed this question
Top Dishwashers Experts
