Question about Mitsubishi CS-35503 TV
No power to set
TV has been off for a year, now it won't power up at all.
Its broke
Posted on May 05, 2010
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
RCA Home Theater HP won't power on.
If the start button has shorted out, you can replace it, however the cost could end up more that the price you'd pay for a new unit.
Feb 09, 2018 | Audio Players & Recorders
TV WON'T POWER ON
The problem is in the power supply board, bad solder joints, or one or two failing capacitors, common issues.
Mar 10, 2012 | Philips 32PT41B 32" TV
Picture on my Toshiba 37RV753B has gone off and the standby light keeps flashing yellow. It was working ok a few hours ago, but I switched it off to go out and now it won't work. It's only just over a
Hello!
If you have used your TV 24/7 for the past year, the issue might be in the power supply. If there are "bloated" capacitors, set will not start up. If you haven't unplug it for a year, it might be staying alive. Once you unplugged the set, those capacitors won't let your set back to normal. That's a big project and requires technical background. If you think you can handle that, open your TV set and inspect TV's power supply board. It will be located near power cord plug or wire. Also, it might be covered by tin shield, which must be removed for further observation. If you see any "bloated" electrolytic capacitors, replace them with same value and voltage. But it might be main board's issue, as well. what is your place's ambient temperature? If it's lower, than 75F, try to warm up the back of the set, before even trying to poke it open. Use hair dryer. First, point it on main board's in/out connectors. Do not overheat! Few minutes might be enough. Then, try to plug the set in and observe the behavior. Any change? turns on? Main board is bad. Same with power supply. If heating up main board area does nothing, try power supply area. If it makes a difference, start looking for bad capacitors.
Good luck,
Let me know results.
Thanks,
Alex.
Dec 10, 2011 | Toshiba Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
good luck,
Alex's Television,
215-806-5980.
Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
We had a storm last night and the storm blew the power out and now the tv won't work I have tried everything we even went to get a new fuse and that won't work. What seems to be the problem? we...
Did the fuse blow? And when you put in the new fuse, did it blow right away.
For five year old TV, the common failure will be the power supply module and the processor on the main board since it will be running 24/7 even when the TV is off, this make it subject to all kind of surges and spikes (I kill the power my TV's when not in use using my power conditioner power switch).
The main board can be damaged also.
Repair shop will more likely to charge you $50 to give you the estimate, typical repair will be $150 and up plus parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 14, 2011 | Polaroid FLM-323B Television
I have a 1 year old Sanyo Vizon HDTV and was watching a show when it suddenly just shut off and would not go back on again. No storms or any other power surges and it is hooked up to a real surge...
Hello
If there is no power indicator LED lights up when the set is sitched ON, the power regulator section inside your TV is faulty. There is a fuse [glass cartridge type]; on the power regulator board. If this fuse blows OFF the set won't switvh ON of the front power light won't light up. Check this fuse first. You can locate it at its power switching regulator board inside, where the AC power goes straight to it after a filternig circuit. If the fuse is blown out, replace ti with same rating. It ratings will be marked either on its edge rims of on its body by colour code lines. Replace the the fuse; if it has blown out, and switch ON the TV. if the replaced fuse also gets failed, do not put any fuse after, the power supply section has some short with it. It is best to replace the power supply board as a card absis; rather than making "surgery" to it. Some components in it will be very difficult to get too. You can buy a new power board from /Vizio Authorised Service Center at your town. OK.
Jul 14, 2011 | Televison & Video
42hl67
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
May 01, 2008 | Toshiba 42HL67 42 in. LCD Television
Televison & Video Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
