Question about Canon Office Equipment & Supplies
Re canon d320 error E100
When I pulled out a paper jam from behind the toner cartridge, a 3 1/4 x 1 1/4 peice of plastic came out also. Any idea where this piece may go? Thanks
  • ddimitt Aug 02, 2009
    fixed the plastic part but still have system error after removing jam
    Guru:
  • 389 Answers
Beside you ended the limit of cheeping cartrige in 3500 copees format A4 mineses, you should not simply fuel his(its) toner, but gain new one cartrige or reenter the cheep microcircuit whereupon fall asleep toner
Posted on Sep 12, 2009
I fixed a paper jam in my Imageclass D320 printer/copier which involved removing both panels and the ink cartridge to get the paper out. Now it says System Errir E100 and I can't figure out how to fix...
E100 is error for laser unit.
Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
Call service...
Hope that helps!
Aug 01, 2011 | Canon imageCLASS D320 Digital Copier
Placed new cartridge - flashing red light - system error E100. What does this mean
these is error for the laser unit fault. Try with new toner/drum cartridge, check if the hinges of the doors working properly ( because they opens and close laser shutter ) or replace laser unit or DC controller.
Hope that helps!
Jun 13, 2011 | Canon imageCLASS D320 Digital Copier
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Mar 17, 2009 | Canon D320 imageCLASS Digital Copier
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
Systems Error E100
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Error paper jam
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp 130 paper jamed
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Jan 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Imageclass D320 "Install cartidage"
I believe the toner Cartridge has a tab that works a switch when inserted into the machine. sometimes it gets broken.
Aug 03, 2007 | Canon imageCLASS D320 Digital Copier
167 people viewed this question
old marine
old marine
