Question about Vizio SV420XV 42 in. LCD TV
Dvd's not playing in correct color
When i connect my upconverting dvd to my vizio lcd through an hdmi cable, my dvd's play only in bright blue/orange/pink. I have gotten a new hdmi cable and dvd player and it still happens, now i'm wondering if it is the tv.
  • ewilhelmi Aug 04, 2009
    i just bought the tv brand new about 3 months ago. and just today, i tried hooking the dvd player up with a/v cables and the dvd's played fine. so is this a problem with the hdmi cable? this is the second one i've bought and i confirmed with the store rep that they play up to 1080p resolution. i'm lost as to what to do next.
    Novelist:
  • 183 Answers
How old is the TV? It may need a firmware upgrade to support new HDMI/DVI formats
Posted on Aug 02, 2009
How do I get my dvd player to play on my 60 inch vizio led.
Connect the DVD player to the Visio with an HDMI cable into 'Input 1'. Use the 'Input' button on the remote to select the correct input. If Input 1 is used, try another input.
Dec 21, 2014 | Vizio Televison & Video
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
When I am watching a DVD, the picture messes up and is replaced by scrambled colors (noise) and then the picture returns. It does this periodically while I am playing a DVD. It can happen while the DVD...
This is most likely happening because your tv is upconverting the dvd signal to be compatible with your hdtv. If your dvd player has no upconverting feature of its own then it is more likely to happen. It's just your tv trying to compensate for the low quality signal coming from your dvd player resulting in intermittent scrambling or "noise". You should try to invest in a blu ray player when possible.
Jun 26, 2010 | Vizio SV422XVT 42 in. LCD HDTV
When I play a DVD it is in Black and White, how
check your component video cables, make sure they connected to the same color on both the dvd player and the tv.
Jan 16, 2010 | Vizio VO47L 47 in. LCD TV
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Inaccurate color with HDMI input
That does sound like it is a compatability issue. Have you tried everything in the menu..Setup wise? Let me know. GURU JAY
Dec 15, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Vizio SV420XV 42 in. LCD TV Logo
167 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
