Question about Philips Magnavox 51MP392H Rear Projection Television
Tv keeps turning off on it's own, is at home repair possible, and how to do it?
  • 11,896 Answers
The power supply will need to be replaced. This is the box that connects to the plug-in wire.
If you can get a soldering Iron, then you can solder off the old joints, find the number written on the power supply and Go to
Philips
.PartStore.com
or
www.MCMElectronics.com
or
stores.shop.ebay.com/LCDPAYLESS__W0QQ_armrsZ1QQ_fsubZ3123744
($30)
or more if you google philips magnavox power supply.
MARK ALL WIRES WITH COLORED TAPE SO YOU KNOW WHICH ONES WENT WHERE!
Then simply resolder new joints and wires.
Posted on Aug 02, 2009
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 | LG 55LM6700
Keeps turning off saying protection
It could be possible your tv volume is too high and the speakers are ment to take in a low volume level and amplifiy the signal themselves. That or there is an electrical malfunction with the device.
Oct 08, 2012 | Samsung HW-E350 Crystal Surround Air Track...
Doesnt want to turn on anymore
Most likely a shop repair, too many possible reasons for a home repair.
Aug 27, 2012 | Samsung TXJ3678 36" TV
The red color does'not work, the screen appear green only
Unfortunately, it's not possible to give you any advice about where to start trying to repair this problem on your own. Missing colors on a TV can be caused by many things: simple bad solder connections, component failures, or a bad picture tube. Without the necessary test equipment and service information, it's nearly impossible to fix many troubles.
The only suggestion I can make is to take this set to a service shop (or call for home service if it's too large to carry) and get a repair estimate if you really want to keep the TV. Or use this as an excuse to replace the set. Especially if the tube is bad, repairs may be uneconomical.
I wish I could offer more help. Good luck and thanks for using Fixya~
Feb 02, 2010 | Televison & Video
Shuts off a few seconds after you turn it on
possible power transformer tv going into protection mode
Aug 25, 2009 | eVision EC720E 20 in. TV/VCR/DVD Combo
The tv keeps trying to come on with the beeping like a bird then
Most failures with these LCDs are due to a defective power supply. The repair itself might be a DIY with basic hand soldering skills and possibly know how to use a multimeter (optional).
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
*When power button is pressed, the LCD will attempt to turn ON but it turn OFF again.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
If you need further assistance, write to jah2mil@hotmail.com
Aug 18, 2009 | Samsung LN-S4051D 40 in. LCD Television
Tv won't turn on, keeps flashing red, will not turn a solid color
Sounds like the lamp needs to be replaced.
Before any repair or replacement, unplug the tv from the electricity for an hour, plug it in. This forces a system reset on the tv and may solve the problem. More likely you need a new lamp.
Aug 17, 2008 | Panasonic PT-50LC14 50" Rear Projection...
RCA F36650 power problem
Apparently, a power supply weakness re-occurring........
Possible incomplete or incorrect repair the first time.....
Have it diagnosed by a qualified RCA tech......
Always a possibility = IHVT = 257805 or asti 2078.......T.
Please rate this solution..........................
Nov 11, 2007 | RCA F36650 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
