Question about Epson Stylus Photo 1200 InkJet Printer
Epson 1200 hi, every time i try to print the carts goes far left hand side and sticks there banging backwards and forwards. i am not to sure what this could be someone suggested the laser? any help is appreciated
Try cleaning and putting a small quantity of oil the shiny metal bar that the print heads slide along. Take care not to get any oil on the rubber drive belt. Any thin oil for sewing machines or bicycles will do, even WD-40 or 3-in-1 on a tissue is fine. This is probably too late for the questioner, but someone may find it useful.
Posted on Oct 16, 2010
Epson Workforce 3640 print head with ink cartridges stuck on right hand side. Error message appears. How do I unjam it?
There is a small lock in the chasis of the head. Move the head to right you can see a plastic on the head moving path. push it to backwards. Now you can move the head to left.
Jun 02, 2017 | Epson Office Equipment & Supplies
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
Epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Jan 15, 2010 | Epson Office Equipment & Supplies
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
Black is full, colors are "low", refuses to print anything
If you have a look on this site you will see there are far more reported problems related to Canon than Epson however the choice is yours.
As to your cardridge problem. The Epson status monitor measures the amount of inkshots used by each cart individually. You know they have chips which indicate when the cart is empty and yet you have not bothered looking for a reset programme. Who's fault is that? The manufacture?
Give this a try, make sure to read the instructins before using.
Sep 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Print quality Epson Laserprinter C1100
Sounds like you need to clean the laser lens to me. On the R/H side of the printer is a small panel, just pull this off. Now open the front cover, on the R/H side is a lever, pull this forward. Now look again inside the panel you removed earlier, there is a green "stick". Just pull this backwards and forwards a few times to wipe the lens clean. Put everything back and try a test print. Good luck.
Jul 07, 2009 | Epson Aculaser C1100 Printer
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
My Epson Stylus CX6400 printer is not printing
lift the scanner body as though you were replacing the ink carts and it's on the left hand side
Nov 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylys R300 not printing black
have you tryed a head clean? try this if it still does it what i did when mine did this i found it was the ink cart take the ink cart out get a cotten woolplug cut one end off and stick it in the bottem of the ink cart with the other end that still got the wool on just clean insite printer where cart goes regards mark
Sep 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing problems after changing Cyan and Magenta cartridges
Try cleaning the contacts and cartridge sensors as well as the cartridges. Try deleting the printer settings and reinstalling. If you?re printing high res. Set the printer to default, and try printing again. Hope it works out
Feb 21, 2006 | Epson Stylus CX5200 All-In-One InkJet...
Epson Stylus Photo 1200 InkJet Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
