Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
14hp ohv engine getting very hot,briggs
Started my mower today and it ran really rough,no power and got very hot.the exhaust pipe down to the muffler started glowing red.shut it down and removed the muffler thinking maybe something had plugged the system,nothing there.started it without the muffler and it still ran rough and got hot again,dont know whats going on.
    Scholar:
  • 148 Answers
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Posted on Aug 05, 2009
Briggs 5 hp backfires through muffler
Exhaust valve is not closing completely or the valve seat is cracked.
Sep 24, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start
The muffler may plugged
Aug 12, 2014 | Briggs & Stratton Garden
18hp ohv cuts out after it gets warm or hot like it is running out of gas
I have a 12.5 hp Briggs & Stratton on a Murray that did that. The carburator is right above the muffler and when I replaced the muffler, I didn't put the heat shield between the muffler and carburator back on. The added heat from the muffler was vaporizing the gas in the carburator where the engine would no longer run once it got hot. Replacing my heat shield and putting a longer pipe on the muffler to get it away from the carburator solved my problem.
Aug 05, 2013 | Craftsman Garden
17hp kohler ohv runs rough and muffler glows red hot
muffler full of carbon remove muffler heat up red hot throw in bucket of cold water remove and throw as hard as you can on pavement clean carbon out of exhaust part of headt make sure piston is all the way up you dont want carbon in your motor reinstall thank me
Oct 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I hev a briggs & Stratton 5.25hp lawnmower and
I would need the engine numbers to tell ya what to do for sure. It sounds like the engine is too full on oil. Check oil levels carefully.That engine capacity is only 1 pint/16 to 20 oz's ALSO you friend may have cleaned under your deck and turned the mower with the aircleaner DOWN. That causes oil to flow from the crankcase into the air cleaner and muffler.That aircleaner is a dry paper and should not have any oil on it, If this is the case then the oil accumulated in the muffler will burn off in time. Oil soaked paper aircleaners will cause this engine not to start.IT CANT BREATH
Oct 21, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
5 hp briggs and stratton mower is hard starting when hot.
Most times the briggs engines start hard when hot because the exhaust valve is leaking at the seat.If you hear a hissing noise from the muffler when you are trying to start instead of a good crisp pop it that is a good indication the valve is burnt.To be sure you would have to have a compression or leak down test done on engine.A valve job is not an easy job if you don't have the right tools.
Jul 29, 2009 | Troy Garden
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,438 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
