Question about Optimus STA-795 Receiver
When inserting speaker wire into RIGHT speaker slot nothing happens on both A & B. Both speakers are brand new KLA and they both work. Can I fix this myself or should I take it in to Radio Shack?
Volvo 2000 s 80 Radio/CD player screen lights up, but nothing comes out of speakers. Occasionally, I will here a speaker pop. How 2 diagnose? Water on floor. Possible damaged amp?
doesnt sound good ..water there
could be bad earths
amp may have a fuse
speakers need to be tested manually
these links may have wiring layouts etc
VOLVO Car Radio Stereo
Audio Wiring Diagram Autoradio connector wire...
Volvo Radio Wiring Diagram
Oct 11, 2016 | 2000 Volvo S80
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Dec 29, 2009 | MTX X702 Car Amp
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 5 1/4′
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 07, 2009 | 1992 Cadillac Eldorado
How to wire a kenwood kdc d300
All components on your Amplifier should be labled. Ground Will go to any ground on your Vehicle Ex. A bolt under your trunk floor cover. Power has to be ran from your positive terminal onto your batter and throught the interior of your car to your amps 12v +. The MEMORY TERMINAL IS NEEDED FOR FUNCION! It will be between Ground and POWER or NEXT TO POWER.. This has to be ran to your cd players BLUE MEMORY wire or you can bypass it directly to the POWER, WARNING!!! if you use the bypass method, put a switch that you can pick up from any autozone or such between the two points to shut off the amp, other wise it will run constatly and kill your battery. The two RCA's have to be plugged into the back of your cd player and ran back to your amp and plugged into the Primary Slot (red-white) and finnaly the +.- speaker wires need to be ran to your subwoofers. Once all conected pop in a cd, adjust your cd players bass settings and also adjust your lows, mids, and highs on the amp to fine tune your speakers. IF you are looking to maximize your speaker wattage, you can use the bridge teqnuiqe. But beware you are going to doubble the ammount of power into each speaker. Take both positives, or if only one speaker just the single possitive, and place it into the Right SPEAKER insert on the Amp, and take both negitives and place it into the LEFT SPEAKER insert, and run the wires like normal to each speaker, 1 wire per - one wire per positive, in doing so both speakers run using maximized power usage
Sep 11, 2008 | Kenwood Car Audio & Video
Jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Sep 04, 2008 | Car Audio & Video
Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Jul 11, 2008 | JVC KD-G110 CD Player
Only one sub works
The amp should produce no output when using the left negative and the right positive.
If the amp works bridged (left positive and right negative) with one speaker AND works when you connect one speaker from the left positive to the right positive, it would appear as though the right channel isn't getting any signal.
Try inserting only the left signal cable (nothing plugged into the right RCA jack) to see if the right channel will work when a speaker is connected to the right channel speaker terminals.
Jun 30, 2008 | Sony XM-2002GTR Car Audio Amplifier
Top Optimus Audio Players & Recorders Experts
Ben Armstrong
Larry Stiles
Larry Stiles
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
