Question about Goodman CKL36AR36 Air Conditioner
Not blowing cold air. Checked outside unit and looks clean but fan not turning
  • 30 Answers
You may have a bad capacitor, fan relay/contactor, or motor. Check the capacitor for the fan, if the capacitor is ok, then check the fan relay/contactor. If this is ok, then the fan motor is bad.
Posted on Aug 05, 2009
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Air conditioner not working
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Sep 08, 2008 | Heating & Cooling
Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
186 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
