Question about Radio Communications
Tk-3100 on 440 mhz band?
My Tk-3100 has no documentation and when i transmit my freq counter says 443.2625.
My problem is that it seems to be transmitting on 443 (because it picks up on my scanner and my TK-380 is recieving it also) but when i transmit on 443.2625mhz (with tk-380) the tk3100 wont pick it up! Is thier an option to have seperate transmit/recieve frequencys? I set the 3100 on accept all for QT and i monitored the recive still nothing, just static.
  • 2 more comments
  • maxfreke88 Aug 02, 2009
    I have the manual, and have read it thoroughly but is the 460 band.
    "I set the 3100 on accept all for QT and i monitored the receive still nothing, just static." QT= Tone code
    Tone code (QT) only takes it out of squelch, squelch is defeated by pressing the monitor button.
  • maxfreke88 Aug 03, 2009
    OMG!! Thank you. I programmed my Tk-380 to transmit 5mhz Higher, and voila they worked perfectly together! Thanks so much!
    Brigadier General:
  • 4,090 Answers
There is a 5mhz difference or offset between transmit and receive on all transceivers. However they should automatically compensate for this if runninhg normal. It sounds as if the auto switch relay between trans and receive is not working. It may need some intervention to correct this
Posted on Aug 02, 2009
    President:
  • 1,714 Answers
It's the 'tone code' that you have to put in so the radio will send the tone code or you can x-mitt and receive. Find out if there is a tone code for the frequency that your using.
  • Craig Butler
    Craig Butler Aug 02, 2009
    What is the frequency range for the TK3100? Is it able to receive that Freq., 443.2625mhz??
  • 11,896 Answers
  1. Results for: Tk-3100 manua
  2. User Manual: Kenwood Protalk TK-3100 Two-Way Radio Member Discussions. for Kenwood Protalk TK-3100 Two-Way Radio. Please help me find the manual for this Kenwood Protalk TK-3100 Two-Way Radio ...
    phone.manualsonline.com/manuals/.../kenwood_protalk_tk_tk3100k2.html
Galaxcy DX 66v freq counter and radio slide up and down 3-5 clicks. Not all the time. Nothing I do seems to help
set your mode for AM with frequency counter reading 26.965 mhz on band E. ( channel 1 ) Now you have to adjust VR 1 for 26.965 mhz if its not reading it already . Now set the counter and the radio to 27.405 mhz ( channel 40 ) check for 27.405 mhz . If its off by .003 to .005 thats really nothing but if its off by .3 to .5 thats when it really off frequency .
Apr 20, 2012 | Galaxy Radios DX-66V Base CB Radio
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
Can't talk on mic above 148.000
If you are a licensed Amateur operator you should know why you can't talk above 148 MHz. The band is 144 to 148 and the radio is programmed to prevent out of band operation.
If you are not licensed, you will be arrested for transmitting with the radios and fined.
Nov 14, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Gtl dx will not transmit below 26.955
First off, the 200 GTL DX is a 10 meter radio. Running it on 11 meters (CB) is illegal, as it is not FCC type accepted. If you go below 26.965 mhz, you are outside of the 11 meter band, and operating illegally.12 meters does not start until 24.930, so ultimately, the freq's between 24.930 and 26.965 mhz are restricted even to a licensed amateur radio operator.
Jul 09, 2009 | Cobra Radio Communications
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Dx-88 HL
You'll need to take it to a repair shop. Because it transmits its under FCC rules so a certified tech needs to work on it.
Or take it back to where you got it and have them correct the problem.
Dec 29, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Yeasu FT 897D
I suspect that the extended transmit will really allow you TX on 2 Meter from 136-174 or thereabouts even with modifications.
At any rate, Air Bands are amplitude modulated, have you tried switching mode to "AM" when operating 116-136MHz??
Would you post back please on how the modification (extended transmit) was done; software programming of the EEPROM or jumpers (JP1001-1009).
Good luck and kind regards.
Nov 22, 2007 | Radio Communications
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
128 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
