Question about Hoover HDC6 Electric Dryer
Will not switch on- button will not stay on
The unit makes a buzzing sound and will not stay on, when the on/off button is pressed. Bussing seems to come from the relay on the small pcb inside the unit.
When we bang the side of the unit while pressing the on switch, it will then stay on. But pressing the on / off switch dose not turn it on. Is this switch a micro switch like the heat one below it which clicks on and then push to click off.
Or is it a contact type which activates the relay. If this type i suspect the relay is duff.
  • colin-999 Nov 25, 2007
    Should have said 'But pressing the on / off switch dose not turn it off'
  • jimmy780 Feb 05, 2008
    I have the same problem, it heats up fine but the on/off switch will not stay in. If kept pressed in the dryer will work but makes a buzzing noise.
    Any ideas ????
  • 46 Answers
At the rere of the switch there is a small relay board. replace this and ur problem will be solved (ex hoover engineer)
Posted on Feb 08, 2008
Indesit idc75 tumble dryer not working
Trying to help here. There was probably a switch latch at the place were you push your button to open it. When they pulled the latch it broke the contact signal plate. Now the dryer doesn't know when the door is closed. So it want start.
Aug 15, 2013 | Dryers
sounds like u got a bad motor. try holding the lid or door switch in while u press the start button. if u give the tub a little help and it starts going then it is the motor.
Jul 25, 2013 | Dryers
Unit is hot all around the freezer. Items on the top two shelves of feezer are not frozen. A kind of buzzing sound when the unit is running.
I would check the condenser grill. It sounds like it is dirty and not able to disperse the compressor generated heat to the air.
Now the bussing sound, is your condenser grill fan operating? If not, then I would suspect the fan motor, or contactor-relay or the start capacitor.
Sep 08, 2011 | Kenmore Side by Side Refrigerator
I have a 92 caprice and it makes a buzzing noise when in drive and reverse. When I put it in park the buzzing stops. What could this be?
The noise is from your transmission.
Run the car until it's hot. On a level surface take the tranmission through the gears PRNDL and back again into Park. Check the level of transmission fluid with the car running. Top it off to where the lvel is between the ADD and FULL marks. DO NOT overfill.
If the level is good or topping it of doesn't fix it you'll need to have the transmission checked
Jul 20, 2011 | 1992 Chevrolet Caprice
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Dryer makes a bussing sound when start button is pushed but doesn't start
It sounds like your motor has gone will buzz really bad when it is tring to start and cannot...
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 10, 2010 | Roper Dryers
The stop button will not stay and makes a buzzing
This sounds just like you have a bad door switch. You check it by taking the two wires off of it and taping them together. Then try the dryer. It should take off and run normally. If so, replace door switch. Good luck.
Oct 21, 2009 | Hoover HDC6 Electric Dryer
Buzzing sound from Relay
The problem is a capacitor at location C622 470mfd and must be changed. Use equal or better voltage rating
Mar 10, 2008 | Sanyo DS25390 TV
Hoover HDC6 Electric Dryer Logo
286 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
