Absolutely no sound - Audio Players & Recorders
  • 11,896 Answers
Remove the top cover of player and look inside for little glass fuses. Make sure they are good. A thin wire inside should be running all the way across the fuse.
I fuses are good, then look at the little silver capacitors on the circuit boards. Check to see if there are any swollen capacitors or any burn marks on the system board. If there are any, it will have to be replaced.
Posted on Aug 02, 2009
Philips tv no sound on hdmi
I had a picture but no sound...contacted Philips support which was absolutely no help. Problem fixed by running the auto-channelling...it takes a few minutes but the sound came back when it was finished...good luck and hope it works for you.
Dec 02, 2013 | Philips 47PFL3704DF7 47 LCD TV
No Audio on Computer
your system need sound drivers and after install you check sound is working absolutely :) you find driver from drivers.freesoftz.com
Jan 10, 2012 | Computers & Internet
My new acer aspire one netbook absolutely refuses to power up
if its brand new I'd suggest contacting Acer, sounds like there is a hardware fault.
Nov 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
I hear absolutely no sound and when i go to turn it up it tells me i have no sound device registered
Is your sound card installed? Maybe it needs an updated driver. Go to Device Manager and see what that says about your sound. If that's all good, then you probably either have a bad connection with you plug in.
Nov 16, 2009 | HP Compaq WF1907 Monitor
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
Peavey classic 30, new tubes and PT with absolutely no sound
I'm not sure what "PT" is , but the heater voltage is separate from the other voltages required for this unit to function properly. Please note that with tube systems, there are voltages in the 300-400V range that can cause injury. If you do not have experience with tube based electronics, I would suggest that you bring this to a service center for repair.
Please update this with what you mean by "PT" and we'll continue from there.
Thanks,
Dan
Nov 12, 2008 | Audio Players & Recorders
No Picture, but have sound
This is a poor manufacturing defect. Visit this forum for more information on the issue.
May 13, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
No picture, buzzing sound
It sounds like the horizontal output transistor may be shorted....Can you feel any static charge on the face of the pix tube?
Nov 15, 2007 | Toshiba 36A43 36" TV
13 people viewed this question
 Grubhead
Grubhead
