Question about LG WM-12230FB Front Load Washer
LG WD12230FB front-load washing machine Error code SE
LG WD12230FB front-load washing machine starts to add water to the load and then stops flashing the error code SE. Checked the user manual and there is no such code. Any idea what the problem is?
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Posted on Aug 23, 2007
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
Brussels
  • 16 Answers
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
  • 113 Answers
SOURCE: LG TROMM WASHING MACHINE FRONT LOAD
Here is text of very helpful email from LG
When you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that
may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the
amount you would normally use in a conventional top-loading machine. However,
the HE and the conventional detergents are different formulae, and your machine
will not perform as efficiently or effectively. Using half the required amount
of regular detergent will
give half the cleaning performance. As the new LG washers accept a larger than
usual load, the cleaning performance could be further reduced. In addition to
the reduced cleaning, there will be oversudsing. The excess suds will cause the
washer to stop and rid itself of the suds before continuing its cycle. Getting
rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which
can result in mold and even mildew growth in your washer. Should this occur, do
a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any
odors accompanying it. This procedure may need to be repeated a couple of times
depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water
temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures
the detergent/suds residue in the water during the rinse and then makes an
adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance
is detected or if the suds removing program operates, the wash time will be
increased.
A built-in water heater in the washer assures that incoming water is the correct
temperature to optimize cleaning performance. Most laundry detergents must be
activated at certain temperatures to work correctly. We use thermisters
(electronic thermostats that have a high degree of accuracy) to detect incoming
water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is
pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This
increases the mechanical action to achieve best cleaning performance. The
rollers gently move fabrics
along in the wash cycle.
This action aids in reducing the amount of water required for thorough
cleansing. In contrast with a top-loading machine, which always fills the
machine to a precise measured level of water, depending on the size of load you
select (small, medium, large), the LG machine will "sense" the size of the load
and only recirculate a minimal amount of water, thus making it very energy
efficient, efficient in the use of detergents, and extremely efficient in its
water usage.
Forced Water Circulation in the washer pumps water during the wash. It
recirculates it back up and over the laundry to further increase mechanical
action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional
machine, that it is recommended to dry the seal when you are done with your
laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the
same wash cycle. Different fabrics need to be washed in different ways. Always
sort dark colors from pale colors and whites. Wash separately as dye and lint
transfer can occur causing discoloration of white clothing. If possible, do not
wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items
should not be more than half the total wash load. Do not wash single items. This
may cause an out-of-balance load. Add one or two similar items.
Hope This help
Good Luck!!!
neo
Posted on Feb 27, 2009
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
LG WM-12230FB Front Load Washer Logo
353 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
