Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Magnavox 37" LCD HD TV 3 years old
Since purchase 3 years ago, unit when powered on, will sometimes show green / red "plaid" whether in VGA, Ypbpr or other modes. Usually multiple power offs / on will restore proper function. Problem is intermittenet - initially ocurred rarely, now as of today, can not restore normal function.
TV has minimal usage - less than 1 -2 hours per week since purchase.
Anyone seen this? Ideas for cause / correction?
many thanks,
Steve
  • 106 Answers
You may need to replace the Small Signal Board of your tv.
Posted on Jan 01, 2008
Dynex 37 hiss and plaid screen
There are some components that have gone bad in the board. It could also be due to moisture inside. Please do not continue to use it and refer it to a qualified service technician.
Jul 19, 2012 | Dynex "- 37"" Class - LCD - 720p - 60Hz -...
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a 37" Phillips LCD TV. it will not turn on and the light that used to show green (to signal the tv on) now blinks red. What does that mean?
how many times does it blink red. the will help determine whats wrong. Most lightly its going to give you 6 or 7 blinks whick points to the power supply this is sometimes a false indication to the ssb/signal board being bad. you coulb try the parts or have a tech come out and verify which is the problem.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
