Question about Kenmore HE3T Washer
I repeatly get and f11 error. I click the pause
I repeatly get and f11 error. I click the pause then the start button, I have been trying to wash the same load for 3 days
    President:
  • 1,776 Answers
The F11 code is usually a generic code that indicates a communication error between the central control unit and the motor control unit. A common problem is that the wiring connection jiggles loose or gets corroded. Unplug and reseat the connector at the control board, and this may solve the problem. Also look for any sign of corrosion which is the enemy of good electrical contact. Hope this helped and best wishes.
Posted on Aug 02, 2009
How do I get error codes on my washer
Hi Fred, try this and see if it works: To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed. A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Once you have your code information, you have the option to reach out to the manufacturer to determine what the issue may be, or feel free to reconnect with me and I will attempt to assist you with the best of my ability. Thanks again for your inquiry!
Jul 25, 2013 | Frigidaire FTF2140E King-Size ENERGY STAR
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
It tries to start but then the start light keeps flashing
Hello John Schmader - Sounds like the washer could be experiencing a communication error with main control board, faulty door lock assembly, pump or the timer itself is not operating correctly. Is the unit making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Does the washer display an error code? Try pressing and holding the START and PAUSE/CANCEL button simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify an error (if one displays).
Jan 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
PT reads on display and it will not drain
Frigidaire does not have a "PT" technical error for any of their units. Please try to recall the error exactly by doing the following:
* Wake the washer by pressingany button.* Wait 5 seconds.* Press and hold the Start andPause/Cancel buttons simultaneously.* All LED's will go blank and after a few seconds the controlwill signal the stored code using audible beeps and blinking LED's. The controlwill repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pausebetween repeats affords you the ability to make accurate counts to identify thecorrect error codes.
Aug 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Wont start
First you have to find the error code.
So! To recall an error code,
Wait 5 seconds
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigiaire frontloader washer will not operator error code " LOC "
Wait 5 seconds
Nov 15, 2011 | Washing Machines
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Whrirlpool Front Loader Washing Machine AWO3561 - F11 Fault
Try unplugging the washer for at least 30 minutes before assuming you have a failed component. Sometimes you may experience a momentary glitch in the CCU. Unplugging the washer for this duration will often reset the error and return to normal operation. If the error code reappears, and it was just recently replaced, I strongly recommend getting in touch with the repair service you used. Most reputable companies guarantee their parts and labor against defects (some companies as much as 90 days). If this is a repeat failure, it may just be a bad lot of CCU boards and the company should replace it free of charge. I hope this helps you. Let me know if you require additional assistance.
Sep 13, 2008 | Whirlpool Washing Machines
Electrical problem
Teecee, F11 is a communication error between the main board and the motor control board. The main board is on top and the motor control board is behind the lower panel. Sometimes the harness to these boards become loose causing this error. You would have to get at them and reseat the connections. F dl has to do with the door lock mechanism. You might of just had the door open when you reset the machine. To get at the main board on top you have to remove the 3 screws in back for the top. It will then slide back and off. To get at the motor control board, you will have to remove the bottom panel. The board will be in the back. Catriver..post back.
Oct 25, 2006 | Whirlpool GHW9150 Front Load Washer
Kenmore HE3T Washer Logo
190 people viewed this question
Sal De
fordexpert
Robert Rankin
