Question about GARDENA Water Timer #31169-4
Gardena WT 1030. When in use all lights are flashing
This has happened twice and cause over watering. the unit can be set up to operate correctly but once the timer switches on all lights start flashing and the valve stays open
Mike258
  • 1498 Answers
SOURCE: gardena c 1060 water timer problem
Hi Cornwell,
I have timers similar to yours. Happens more often than I like to think about. Here's what I do:
  • Make sure there are new batteries, Check the contacts in the battery compartment for corrosion.
  • Check the manual on/off for unit functionality
  • If the device is new (warranty) and it still does not work, exchange it. It's not your problem.
  • If it's out of warranty and does not work, you have nothing to lose by opening it up. Some of mine just needed the gear box to be nudged.
Good luck and happy watering
Mike
Posted on Jul 25, 2010
SOURCE: My Gardena T 1030 D
1) I might have that manual in English:
http://waterheatertimer.org/pdf/Gardena-T1030.pdf
http://waterheatertimer.org/pdf/Gardena-T1030-MANUAL.pdf
2) If manual above doesn't work, I also used Google translate to translate Gardena manual; from Italian and German if I recall:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
You can enter whole sentences into google translate, and make sense of 70-80%.
I sometimes answer questions in Spanish at fixya using the translator. So we're not helpless any more.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 10, 2011
  • 157 Answers
SOURCE: I have recently moved into
Hello. Here is the link to a download.
Hope it helps.
Posted on Apr 03, 2011
SOURCE: A FRIEND GAVE ME A
Some Gardena manuals appear on following link, and additional manuals are posted as found:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Also Google search "Gardena C1030 .pdf" or "Gardena C-1030 .pdf"
Be sure and add .pdf to search parameter to help isolate manuals from other internet posts
Gardena for some reason does not have manuals easily available as of today's date.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 14, 2011
SOURCE: I do not have a
There are different 1030 gardena timers, and some gardena products have 3 different numbers, and sometime different timers have identical number.
Some Gardena manuals appear on following link with images of different products:
Posted on Jun 30, 2011
My gardena water timer won't stop bipping. See the picture. Is it the battery ?
for the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
May 28, 2016 | GARDENA Hardware & Accessories
Need manual for gardena model T 1030 D i can only find T 1030 without D...!
I cannot find T1030D manual posted anywhere, Aug 2011.
The Gardena site does not return emails or post manuals.
You can try the following 'possible instructions' and then add a comment saying what you discover.
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
Aug 13, 2011 | GARDENA Water Timer
I do not have a manual and do not know how to set the timer correctly I have a gardena 1030
Jun 29, 2011 | GARDENA Water Timer
I have a Gardena WT 1030 water timer. The last battery is 10 months old and I have now replaced it as it is at my holiday home (very near to the sea) and we will not be back before April. The timer has...
I have Gardena 1030 manual
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
Jan 05, 2011 | GARDENA Water Timer
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Lost instructions on how to set timmer need set of instructions for gardena 1030 water timer please
I googled Gardena 1030 instructions and there is a site for what you are looking for. It is about the fifth one down. lawnandgarden.manualsonline.com
Oct 03, 2009 | Garden
GARDENA  Water Timer #31169-4 Logo
659 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
