Question about Nikon Coolpix 5700 Digital Camera
I've just formatted memory card card for coolpix 5700. When I switch camera on I see a black screen with flashing lines of light and no image. I have a 999 code on the data screen. Is this related to my problem?
    Genius:
  • 1,234 Answers
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    How do i switch from internal to external memory on a coolpix 5700?
    If you remove the memory card the internal memory should kick in.
    Feb 09, 2013 | Nikon Coolpix 5700 Digital Camera
    NIKON COOLPIX 5700 WILL NOT FORMAT MEMORY CARD
    Go to set up and go to default settings and reset your camera.
    Mar 19, 2012 | Nikon Coolpix 5700 Digital Camera
    I own a Nikon Coolpix 5700 and recntly I face a problem with the memory card, The memory card is Nikon Compact Flash 32MB and the camera shoes that I can have Basic 51 photoes, Noraml 26 Fine 13 and Hi...
    Nikon Coolpix 5700 Digital Camera memory card failure:
    This camera has capabilities which far exceed the data storage of a 32 MB memory card. Put what you can onto the Nikon Compact Flash card and purchase another, larger, 2 GB card for your other storage. This should easily meet both the needs of the camera and your own. The original card must have had data deterioration or a mistake was made in transferring the pictures.
    Go to Google and download their Picasa App; it is great for anyone transferring their photography from one storage type to another and you can use it for publishing material to the Web or to your family group e-mail.
    Please comment on the success of this solution!
    Sciencewoman
    Apr 15, 2011 | Nikon Coolpix 5700 Digital Camera
    Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
    Not sure if this helps, but it worked for me on a Coolpix 5000.
    I tried a 4Gb card, and the camera formatted it and reported out-of-memory. The problem seams to be that that max 2Gb is supported
    What I did was partitioned the card into 2 sections with 2Gb on each. I then formated them to FA16.
    This worked - but you can only use half of the card (i.e. 2Gb)
    For the tools I used a Linux laptop with CF reader. The tools are build in here (fdisk and mkdosfat). I don't know how to do it on windows.
    May 18, 2009 | Nikon Coolpix 5700 Digital Camera
    Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
    Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
    Monitor is blank:
    • Camera is off.
    • Batteries are not correctly inserted or battery-chamber
    cover is not properly latched.
    • Batteries are exhausted.
    • EH-62B AC adapter (available separately) is not properly
    connected.
    • Camera is in sleep mode. Press shutter-release button
    halfway.
    • Monitor is off.
    • USB cable is connected.
    • AV/Video cable is connected
    No picture is taken when shutter release button is pressed:
    • Camera is in playback mode.
    • Red (!) lamp flickers: flash is charging.
    • Green (AF) lamp flickers: camera unable to focus.
    • Message "CARD IS NOT FORMATTED" appears in
    monitor: memory card is not formatted for use in your
    camera.
    • Message "OUT OF MEMORY" appears in monitor:
    insufficient memory to record picture at current Image
    mode setting.
    Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
    COOLPIX 5700
    Nikon approved CompactFlash memory cards up to 256MB in size for the 5700. The 5700 may be able to handle cards as large as 1GB, but I haven't tested this personally. When this camera was introduced in 2002, 256MB was a really big card. Many older cameras can't handle the 2GB, 4GB and larger cards we're seeing today.
    Jul 25, 2008 | Nikon Coolpix 5700 Digital Camera
    Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
    The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
    Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
    Nikon 5700
    Thanks! I'll give that a shot.
    Jul 14, 2008 | Nikon Coolpix 4600 Digital Camera
    Nikon Coolpix 5700 Digital Camera Logo
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
