Question about Mantis 7225-00-02 2 Cycle Gas Power Cultivator
How to add oil to the gearbox - Mantis 7225-00-02 2 Cycle Gas Power Cultivator
Hi
how do i change, or add oil to the gerabox on my Ford Fiesta Ghia-X
On a 'P' plate?
Thanks
Regards
Richard
Posted on Aug 08, 2009
Would like to know where the top up plug for my gear oil is and if there is a dip stick manual proton savvy bt 2006
Manual Transmissions don't have dip sticks.
2. Manual gearboxes have a drain and filler plug. The filler plug is usually found in an accessible position on one side of the gearbox which has to be accessed from under the vehicle.
To top up the gearbox the car has to be perfectly level so if you need to add oil to the gearbox you ideally need to get the car up on a garage hoist/lift so you can both access the filler plug easily, remove it and pump in the fresh gear oil. The usual correct oil level on these gearboxes is level with the bottom section of the filler plug opening in the gearbox. However you should check with the proton service staff on the correct procedure for topping up the manual gearbox in your car.
Mar 20, 2016 | Proton Cars & Trucks
I just rebuilt a 1993 Lancer wagon gearbox,what type of oil and how much should I use to refill it
90 wt gear oil. with the gearbox installed and level, open the filler plug and add oil until it starts to drip back then put the plug back in.
Mar 17, 2016 | Cars & Trucks
Post hole digger gearbox oil leak
If the instructions do not give you an answer to your question and you can't find any information from the manufacture I would proceed as follows. The oil coming out of the breather is due to the splashing of the oil and the heating of the parts as they work building up pressure. I would tend to believe that as long as there is some coming out there is enough oil to take care of the gearbox.
If there is a separate plug to remove to add oil to the gearbox I would use that as my fill level. I hope this helps.
May 11, 2014 | Garden
Transmission fluid
First, refer to the dip stick top or the vehicle manual to identify which type of fluid to add to your transmission.
I presume you are referring to the more popular automatic transmission for many markets.
Run the vehicle until it is warm.
Remove the gearbox oil dipstick.
Jack the vehicle up a little if it helps, as you will need a drain tray and tool. Creep under the vehicle and remove the gearbox oil drain bung. It's usually at the lowest point, in the gearbox oil pan.
Drain the oil until you have almost no drips.
If you don't wish to replace the gearbox oil filter at this point, then procede to tighten the drain bung back into the oil pan/sump using a fresh washer if needed. Once tight (don't go mad as these can strip easily) you can procede to add your new oil.
You will likely need a very thin funnel to fit into the dipstick tube as this is where the oil is added on almost all Japanese models at least. If you can't find out how much oil to add to your vehicle, then add as much as you dropped out at first, or perhaps a little less as your fresh oil is cold as opposed to the expanded, warmer oil which came out.
Once added, start the vehicle, and go through the gears with your foot on the brake.
With the engine running and in Park, check the gearbox oil level.
You can often get false readings on the dipstick until all the oil you added to the dipstick tube has run into the gearbox, so you might want to check this after half an hour or so.
Run the vehicle, do a road-test, and then return and recheck for any oil leak at the drain bung and the oil level once again.
Gearboxes are very sensitive to having incorrect oil levels, so try to keep it as accurate as possible.
Nov 12, 2012 | 2007 Toyota Avanza 1.3
Noise going into 4th gear what could it be
The gearbox could be low on oil check the oil level depending on the modal there should be a bung on the side of the gearbox at the level the oil should be. If you can't detect oil below the bung you need to add oil. Cheers
Jun 19, 2012 | Cars & Trucks
How check oil in gearbox of a 1999 hilux
if it is a manual gearbox there should be a plug on the side of the gearbox about halfway up unscrew it & by putting your finger in & feeling down you should be able to feel the oil, if not you need to add oil, this plug is also the oil level plug, you add oil until it runs out of the hole,if it an automatic transmission you should find a dipstick similar to the engine dipstick & you add oil through that tube......hope this helps......cheers
Jun 20, 2011 | Toyota Highlander Hybrid Cars & Trucks
How would I go about add/flushing my transmission fluid to my '01 jeep Cherokee? I have looked for an "access" point and can't seem to find it. I have know how to add oil, brake, antifreeze,...
this is not a serviceable item and must be taken to the dealer who has the specialist equipment to perform this operation ,if gearbox works then leave well alone you do not need to change the oil ever .Old wives tale this tranny flush as you call it in america ,A automatic gearbox never needs to be changed ,do you change oil on the manual gearbox ?=?=
Oct 28, 2010 | 2001 Jeep Cherokee
Jaguar xj 2004 (x350 design) - ''gearbox fault'' came on the dashboard with amber light, and the Sport button would not work. Drove10 miles and parked up. 2 hours later restarted and gearbox fault light...
I have been with same problem on a BMW 325i.
It is because you need to add oil. Less oil= extrem temperature!
try to add oil, better to change oil and filter.
regards
Sep 07, 2009 | 2009 Jaguar XJ-Series
Gearbox
what kind of car like certain mazda you have to remove speedometer cable or sensor add gear oil untill you see oil at the bottom of the hole some gear box take heavy gear oil some motor oil 5w30 dont put to heavy oil it gonna be hard shifting when cold cheers let me know what kind of car cheers
Jan 20, 2008 | Visonik V308XT 180W x 2 Car Amp Car Audio...
Mantis 7225-00-02 2 Cycle Gas Power Cultivator Logo
146 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
