Question about Dryers
When i push the start button it doesnt work
When i push the start button nothing happens. we have checked the fuses, plug in and all this is ok.
    President:
  • 1,776 Answers
You need to check the thermal fuse. It is located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long and can be tested for continuity with an ohm meter or multimeter. If it doesn't have continuity, then it is defective and must be replaced. Hope this helped and best wishes.
Posted on Aug 02, 2009
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
Set timer nothing happen after pushing start button
Check 220v voltage at the wall plug.
Check door switch
In back pull off panel and check Thermal fuse at top of element case
Check white fuse lower left on return air (2 wires )
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Kenmore 64672 Electric Dryer
The dryer will not start when you push the switch. Have checked the plug and power at the box. It sounds like the clock on the setting is working, but nothing happens when you push the button.
you may have a bad start button or a bad door switch these are the first thing to check out.if those check ok then you may have a bad motor.i hope this helps good luck
Jan 22, 2010 | Dryers
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
Dryer doesnt work at alll you push the start
make sure the door is shut good nd tight check the breaker for 220 volts
Jul 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
